No 5GHZ and 6GHZ Connections Possible with NWA220AX-6E Acces Point
Hey there,
I am desperately trying to connect my devices, smartphones, PCs and also an Oculus Quest 3 with the 5GHZ and 6GHZ Band of my NWA220AX-6E.
As soon as I am deactivating the 2.4GHZ Band and let the 5GHZ and 6GHZ Band active, the SSID is not visible any more.
I have already set the bandwidth to 160MBS accordingly, since my Device do not support 320MHZ.
I have activated remote Support, maybe you can help me here.
It could not be a compatibility issue ( I Think ), because also the 5GHZ Band is not working as it should be. As soon as I switch back to my older Zyxel AP, everything works. The reason why I upgraded is the new Wi-Fi 6E Features for my Meta Quest 3 Device. With my old AP NWA210AX, I can only use 5GHZ Wi-Fi 6 Features.
I have already updated and reset my device.
Maybe there is actually something wrong with the device itself.
EDIT: I am a step further. The problem is the 6GHZ BAND. If that is activated, my oculus Quest 3 won't find the AP.
Greetings
Chris
Hi @ChrisMoon,
We have a customer who has Meta Quest 3 and can connect to NWA220AX-6E with a 6GHz SSID. Could you add the AP back to your org/site and we can help to check if the AP broadcast SSID in 6GHz? Also, do you have another 6GHz device that can find the 6GHz SSID?
Zyxel Melen0
Hi @ChrisMoon,
NWA220AX-6E is a Band-Flex supported model that can be configured as either 5GHz or 6GHz. It means the radio will be 2.4GHz + 5GHz or 2.4GHz + 6GHz.
According to your description, it seems like you didn't change the band on the radio setting page. Please check the FAQ below to configure it:
Hope it helps.
Zyxel Melen0 -
thanks for the quick reaction.
I already did the band flex settings. Unfortunately my Quest 3 is not possible to see the 6GHz band. I tried everything , even different channels and bandwidth settings.
I could get the 5GHz Band to run now with the AX standard. But there is no point in upgrading to this model , if I have to use the 5GHZ Band that I have already available to my older zyxel AP.
after 4 Hours I removed the device from my nebula account. That’s why you could not connect.
I think , it’s not the AP. It is rather possible that METAs Quest 3 has compatibility issues.Maybe there is someone here , using the device for the identical use case ?
Hi @ChrisMoon,
Zyxel Melen0 -
much thanks for everything , but i did not have the time for it right now. That’s why I have returned the device to my seller.
BUT: It’s not over yet. I will buy another on in the future and then we will meet again.
greetings0 -
ok , so iam back !
I bought a new zyxel NWA B310 access point. Still - no 6ghz WiFi possible - all other bands work.
You can connect from now on , I have unlocked the remote service function.
greetings0 -
Hey,
I would like to inform you about the same issue that is still not solved. I live in Austria, The 6GHZ Band is officially allowed for over 1 year now her in austria. So i really do not know why my Meta Quest 3 is absolutely not able to see a 6GHZ BAND. I activated the 5 and 6ghz Band in settings and tried all available settings, deactived them, activated them - changed them. I really do not know whats the issue here.
Can you look into my AP to help me?Greetings
Hey, Just a quick update. For the first time in 1,5 Years - the 6GHZ band is connected. Maybe Meta did something on their newest update. COOL
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
