How to reinstall my Zyxel NAS326
Hello there,
I am looking for a way to reinstall (not factory reset the settings but full reinstall my NAS326). How could I achieve that?
Best
Could you clarify the purpose you'd like to pursue instead?
Yes. My last files upload resulted in some files uploaded but with 0 MB size.
I've entered the menu and one of the disks was listed a degraded even that the machine was not beeping for degraded disk.
I thought it might be software failure so I've tried to upgrade the firmware to the latest but it was stuck in loading between 10% and 20% (I do not remember the right number).
Now I am no longer able to open the web interface of my Zyxel. When I try to login it loads infinitely.
This is the result of my disks check:
~ # smartctl -a /dev/sda
smartctl 6.3 2014-07-26 r3976 [armv7l-linux-3.10.39] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Red (AF)
Device Model: WDC WD20EFRX-68EUZN0
Serial Number: WD-WCC4M1LAJ3DH
LU WWN Device Id: 5 0014ee 21042759c
Firmware Version: 82.00A82
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Feb 27 16:09:51 2024 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (26580) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 268) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 179 174 021 Pre-fail Always - 4050
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1553
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 043 043 000 Old_age Always - 41679
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 258
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 215
193 Load_Cycle_Count 0x0032 150 150 000 Old_age Always - 150979
194 Temperature_Celsius 0x0022 112 101 000 Old_age Always - 35
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
~ # smartctl -a /dev/sdb
Serial Number: WD-WCC4M2XRF7ZK
LU WWN Device Id: 5 0014ee 21042e2f8
Local Time is: Tue Feb 27 16:09:54 2024 EET
was never started.
been run.
data collection: (26940) seconds.
command.
power-saving mode.
recommended polling time: ( 272) minutes.
3 Spin_Up_Time 0x0027 172 170 021 Pre-fail Always - 4358
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1497
9 Power_On_Hours 0x0032 047 047 000 Old_age Always - 39279
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 259
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 216
193 Load_Cycle_Count 0x0032 150 150 000 Old_age Always - 150631
194 Temperature_Celsius 0x0022 109 100 000 Old_age Always - 38
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 14970 -
There is nothing wrong with that disks. About reinstalling the firmware, you can use a Rescue Stick.
I've downloaded the archive for my NAS326 and extracted it into FAT USB flash drive. I followed the instructions to rename the file and the flash drive files structure looks like this:
user@wb:/media/suvari3v/FAT 8GB$ ll
total 960
drwxr-xr-x 3 user user 4096 яну 1 1970 ./
drwxr-x---+ 3 root root 4096 мар 5 20:07 ../
-rw-r--r-- 1 user user 79 окт 19 2016 ras.bin
drwxr-xr-x 5 user user 4096 мар 5 19:50 .Trash-1000/
-rw-r--r-- 1 user user 949972 окт 19 2016 uboot.bin
-rw-r--r-- 1 user user 36 окт 19 2016 Upgrade_C0
-rw-r--r-- 1 user user 12250 окт 19 2016 usb_key_func.shThen I've followed the instructions again:
- I've shut down the NAS
- I've inserted the flash drive into the front port
- I've started the NAS again
- There was a beeping sound
- Then I've shut down the NAS as it did not shut down itself automatically as per the instructions (after waiting for about 5 minutes)
Now when I start it it does not seems like something is changed. I've logged in the device using SSH and the HTTPD service was not running I was not able to enter the web portal so I've started the service:
~ # /etc/init.d/httpd.sh start
~ #Then the web portal started to load the login from and I've entered my credentials in the web portal but again I see infinite loading and I'm not able to enter the dashboard.
Could you suggest please?
Don't know how you managed to get the stick that way. The content should be
├── nas3xx_check_file
├── nas3xx_fw
│ ├── uboot.bin
│ ├── Upgrade_C0
│ ├── ras.bin
│ └── usb_key_func.sh
├── nas3xx_md5sum.txt
└── Readme.txtWhere ras.bin is a +/- 50MB file, with it's md5sum in nas3xx_md5sum.txt. The .Trash-1000/ directory won't hurt. (All extra files are ignored.)
Thank you for your instructions. I was able to upgrade the firmware to V5.21. The device shut down after the upgrade as expected.
Unfortunately, I am still unable to log in and I see an infinite loop. Here is what I did right after the upgrade:
~ # dmesg
Booting Linux on physical CPU 0x0
Linux version 3.10.39 (root@twsvnnt01652-01) (gcc version 4.8.5 20150209 (prerelease) (crosstool-NG 1.21.0) ) #1 Tue Jan 2 10:45:10 CST 2024
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Marvell Armada 380/381/382/385/388 (Device Tree), model: Marvell Armada 380 STG-328
Memory policy: ECC disabled, Data cache writealloc
On node 0 totalpages: 131072
free_area_init_node: node 0, pgdat c0ec2024, node_mem_map c0f11000
Normal zone: 1024 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 131072 pages, LIFO batch:31
CPU: All CPU(s) started in SVC mode.
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Kernel command line: console=ttyS0,115200 ubi.mtd=4,2048 rootfstype=ubifs root=ubi0:rootfs1 rw rootdelay=2
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 512MB = 512MB total
Memory: 504272k/504272k available, 20016k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xe0800000 - 0xfff00000 ( 503 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc081c8a8 (8275 kB)
.init : 0xc081d000 - 0xc0e6bd5c (6460 kB)
.data : 0xc0e6c000 - 0xc0ec30e0 ( 349 kB)
.bss : 0xc0ec30e0 - 0xc0f10c70 ( 311 kB)
NR_IRQS:16 nr_irqs:16 16LSP version: linux-3.10.39-2014_T3.0p7
sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 171798ms
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410054c9, AUX_CTRL 0x16070000, Cache size: 1048576 B
Console: colour dummy device 80x30
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0xc063c590 - 0xc063c5e8
mvebu-pmsu: Initializing Power Management Service Unit
Initializing CPU Reset module
devtmpfs: initialized
mvebu-soc-id: MVEBU SoC ID=0x6810, Rev=0x4
xor: measuring software checksum speed
arm4regs : 2368.000 MB/sec
8regs : 1458.800 MB/sec
32regs : 1408.000 MB/sec
xor: using function: arm4regs (2368.000 MB/sec)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
irq: Cannot allocate irq_descs @ IRQ194, assuming pre-allocated
irq: Cannot allocate irq_descs @ IRQ226, assuming pre-allocated
bio: create slab <bio-0> at 0
raid6: int32x1 203 MB/s
raid6: int32x2 270 MB/s
raid6: int32x4 283 MB/s
raid6: int32x8 323 MB/s
raid6: using algorithm int32x8 (323 MB/s)
raid6: using intx1 recovery algorithm
gpio-ms: gpio_dev = fe00000 (M: 254, m: 0)
[kernel] gpio_request for GPIO[24] failed with error number: -517
[kernel] gpio_request for GPIO[31] failed with error number: -517
[kernel] gpio_request for GPIO[44] failed with error number: -517
mvebu-pcie pcie-controller.3: PCIe0.0: link down
mvebu-pcie pcie-controller.3: PCIe1.0: link down
mvebu-pcie pcie-controller.3: PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io 0x1000-0xfffff]
pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe8000000]
pci_bus 0000:00: root bus resource [bus 00-ff]
pci 0000:00:01.0: [11ab:7846] type 01 class 0x060400
pci 0000:00:02.0: [11ab:7846] type 01 class 0x060400
PCI: bus0: Fast back to back transfers disabled
pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
PCI: bus1: Fast back to back transfers enabled
pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
PCI: bus2: Fast back to back transfers enabled
pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
pci 0000:00:01.0: PCI bridge to [bus 01]
pci 0000:00:02.0: PCI bridge to [bus 02]
PCI: enabling device 0000:00:01.0 (0140 -> 0143)
PCI: enabling device 0000:00:02.0 (0140 -> 0143)
vgaarb: loaded
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
PTP clock support registered
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource armada_370_xp_clocksource
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 64 bytes, default 64
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
fuse init (API version 7.22)
bio: create slab <bio-1> at 1
Btrfs loaded
msgmni has been set to 984
async_tx: api initialized (async)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
****** turn off all LEDs that turned on in u-boot ******
****** blink SYS LED ******
mv_xor f1060800.xor: Marvell shared XOR driver
mv_xor f1060800.xor: Marvell XOR: ( xor cpy intr )
mv_xor f1060800.xor: freeing 1 in use descriptors!
mv_xor f1060800.xor: Marvell XOR: ( crc32c )
mv_xor f1060900.xor: Marvell shared XOR driver
mv_xor f1060900.xor: Marvell XOR: ( xor cpy intr )
mv_xor f1060900.xor: freeing 1 in use descriptors!
mv_xor f1060900.xor: Marvell XOR: ( crc32c )
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 44) is a 16550A
console [ttyS0] enabled
brd: module loaded
loop: module loaded
ahci_mv f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci_mv f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
scsi0 : ahci_mv_platform
scsi1 : ahci_mv_platform
ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 58
ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 58
armada-nand f10d0000.nand: Initialize HAL based NFC in 8bit mode with DMA Disabled using BCH 4bit ECC
NAND device: Manufacturer ID: 0xc2, Chip ID: 0xda (Macronix NAND 256MiB 3,3V 8-bit), 256MiB, page size: 2048, OOB size: 64
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_read_bbt: bad block at 0x000006920000
nand_read_bbt: bad block at 0x00000a6a0000
7 ofpart partitions found on MTD device armada-nand
Creating 7 MTD partitions on "armada-nand":
0x000000000000-0x000000200000 : "U-Boot"
0x000000200000-0x000000400000 : "U-Boot env"
0x000000400000-0x000000e00000 : "Config"
0x000000e00000-0x000001d00000 : "Kernel-1"
0x000001d00000-0x000008700000 : "RootFS-1"
0x000008700000-0x000009600000 : "Kernel-2"
0x000009600000-0x000010000000 : "RootFS-2"
m25p80 spi0.0: unrecognized JEDEC id ffffff
SoC: model = 0x6810, revision = 0x4
o 3 Giga ports supported
o SKB recycle supported for SWF (Disabled)
o NETA acceleration mode 1
o RX Queue support: 8 Queues * 256 Descriptors
o TX Queue support: 8 Queues * 532 Descriptors
o GSO supported
o GRO supported
o Receive checksum offload supported
o Transmit checksum offload supported
o Driver ERROR statistics enabled
o Driver INFO statistics enabled
o Driver DEBUG statistics enabledport #0: is_sgmii=0, is_rgmii=1, phy_addr=1
o Loading network interface(s) for port #0: cpu_mask=0x1, tx_csum_limit=9800o Port 0 is connected to Linux netdevice
o eth0, ifindex = 2, GbE port = 0
giga p=0: mtu=1500, mac=00:50:43:02:02:01 (platform)libphy: orion_mdio_bus: probed
e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
e1000: Copyright (c) 1999-2006 Intel Corporation.
e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd: block sizes: qh 64 qtd 96 itd 160 sitd 96
ehci-pci: EHCI PCI platform driver
ehci-orion: EHCI orion driver
Initializing Orion-SoC USB Host Controller
orion-ehci f1058000.usb: EHCI Host Controller
orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
orion-ehci f1058000.usb: reset hcs_params 0x10011 dbg=0 ind cc=0 pcc=0 ordered ports=1
orion-ehci f1058000.usb: reset hcc_params 0006 thresh 0 uframes 256/512/1024 park
orion-ehci f1058000.usb: park 0
orion-ehci f1058000.usb: reset command 0080b02 park=3 ithresh=8 period=1024 Reset HALT
orion-ehci f1058000.usb: irq 50, io mem 0xf1058000
orion-ehci f1058000.usb: init command 0010005 (park)=0 ithresh=1 period=512 RUN
orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
usb usb1: default language 0x0409
usb usb1: udev 1, busnum 1, minor = 0
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 3.10.39 ehci_hcd
usb usb1: SerialNumber: f1058000.usb
usb usb1: usb_probe_device
usb usb1: configuration #1 chosen from 1 choice
usb usb1: adding 1-0:1.0 (config #1, interface 0)
hub 1-0:1.0: usb_probe_interface
hub 1-0:1.0: usb_probe_interface - got id
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
hub 1-0:1.0: standalone hub
hub 1-0:1.0: individual port power switching
hub 1-0:1.0: individual port over-current protection
hub 1-0:1.0: Single TT
hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
hub 1-0:1.0: power on to power good time: 20ms
hub 1-0:1.0: local power source is good
hub 1-0:1.0: enabling power on all ports
xhci-hcd f10f0000.usb3: xHCI Host Controller
xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
xhci-hcd f10f0000.usb3: irq 48, io mem 0xf10f0000
usb usb2: default language 0x0409
usb usb2: udev 1, busnum 2, minor = 128
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: xHCI Host Controller
usb usb2: Manufacturer: Linux 3.10.39 xhci-hcd
usb usb2: SerialNumber: f10f0000.usb3
usb usb2: usb_probe_device
usb usb2: configuration #1 chosen from 1 choice
xHCI xhci_add_endpoint called for root hub
xHCI xhci_check_bandwidth called for root hub
usb usb2: adding 2-0:1.0 (config #1, interface 0)
hub 2-0:1.0: usb_probe_interface
hub 2-0:1.0: usb_probe_interface - got id
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
hub 2-0:1.0: standalone hub
hub 2-0:1.0: no power switching (usb 1.0)
hub 2-0:1.0: individual port over-current protection
hub 2-0:1.0: Single TT
hub 2-0:1.0: TT requires at most 8 FS bit times (666 ns)
hub 2-0:1.0: power on to power good time: 20ms
hub 2-0:1.0: local power source is good
hub 2-0:1.0: trying to enable port power on non-switchable hub
xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
usb usb3: skipped 1 descriptor after endpoint
usb usb3: default language 0x0409
usb usb3: udev 1, busnum 3, minor = 256
usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb3: Product: xHCI Host Controller
usb usb3: Manufacturer: Linux 3.10.39 xhci-hcd
usb usb3: SerialNumber: f10f0000.usb3
usb usb3: usb_probe_device
usb usb3: configuration #1 chosen from 1 choice
usb usb3: adding 3-0:1.0 (config #1, interface 0)
hub 3-0:1.0: usb_probe_interface
hub 3-0:1.0: usb_probe_interface - got id
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
hub 3-0:1.0: standalone hub
hub 3-0:1.0: no power switching (usb 1.0)
hub 3-0:1.0: individual port over-current protection
hub 3-0:1.0: TT requires at most 8 FS bit times (666 ns)
hub 3-0:1.0: power on to power good time: 20ms
hub 3-0:1.0: local power source is good
hub 3-0:1.0: trying to enable port power on non-switchable hub
xhci-hcd f10f8000.usb3: xHCI Host Controller
xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
xhci-hcd f10f8000.usb3: irq 49, io mem 0xf10f8000
usb usb4: default language 0x0409
usb usb4: udev 1, busnum 4, minor = 384
usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb4: Product: xHCI Host Controller
usb usb4: Manufacturer: Linux 3.10.39 xhci-hcd
usb usb4: SerialNumber: f10f8000.usb3
hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
usb usb4: usb_probe_device
usb usb4: configuration #1 chosen from 1 choice
usb usb4: adding 4-0:1.0 (config #1, interface 0)
hub 4-0:1.0: usb_probe_interface
hub 4-0:1.0: usb_probe_interface - got id
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
hub 4-0:1.0: standalone hub
hub 4-0:1.0: no power switching (usb 1.0)
hub 4-0:1.0: individual port over-current protection
hub 4-0:1.0: Single TT
hub 4-0:1.0: TT requires at most 8 FS bit times (666 ns)
hub 4-0:1.0: power on to power good time: 20ms
hub 4-0:1.0: local power source is good
hub 4-0:1.0: trying to enable port power on non-switchable hub
xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
usb usb5: skipped 1 descriptor after endpoint
usb usb5: default language 0x0409
usb usb5: udev 1, busnum 5, minor = 512
usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb5: Product: xHCI Host Controller
usb usb5: Manufacturer: Linux 3.10.39 xhci-hcd
usb usb5: SerialNumber: f10f8000.usb3
hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
usb usb5: usb_probe_device
usb usb5: configuration #1 chosen from 1 choice
usb usb5: adding 5-0:1.0 (config #1, interface 0)
hub 5-0:1.0: usb_probe_interface
hub 5-0:1.0: usb_probe_interface - got id
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
hub 5-0:1.0: standalone hub
hub 5-0:1.0: no power switching (usb 1.0)
hub 5-0:1.0: individual port over-current protection
hub 5-0:1.0: TT requires at most 8 FS bit times (666 ns)
hub 5-0:1.0: power on to power good time: 20ms
hub 5-0:1.0: local power source is good
hub 5-0:1.0: trying to enable port power on non-switchable hub
usbcore: registered new interface driver usblp
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
hub 3-0:1.0: state 7 ports 1 chg 0000 evt 0000
mvebu-rtc f10a3800.rtc: rtc core: registered f10a3800.rtc as rtc0
i2c /dev entries driver
md: linear personality registered for level -1
md: raid0 personality registered for level 0
md: raid1 personality registered for level 1
md: raid6 personality registered for level 6
md: raid5 personality registered for level 5
md: raid4 personality registered for level 4
hub 4-0:1.0: state 7 ports 1 chg 0000 evt 0000
device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
dm_crypt using the OCF package.
cpuidle: using governor ladder
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
hub 5-0:1.0: state 7 ports 1 chg 0000 evt 0000
mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
sdhci-pltfm: SDHCI platform and OF driver helper
armada-cesa-ocf f109d000.crypto: mv_get_cesa_resources: Total CESA HW channels supported 2
armada-cesa-ocf f109d000.crypto: mv_get_cesa_resources: CESA feature: int_coalescing(1)
armada-cesa-ocf f109d000.crypto: mv_get_cesa_resources threshold 0x2, threshold_time 0xff
mvCesaInit: channels=2, session=640, queue=256
armada-cesa-ocf f109d000.crypto: cesa_ocf_probe: CESA driver operate in ocf(0) mode
ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
ata1.00: ATA-9: WDC WD20EFRX-68EUZN0, 82.00A82, max UDMA/133
ata1.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata2.00: ATA-9: WDC WD20EFRX-68EUZN0, 82.00A82, max UDMA/133
ata2.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32)
cesadev_init(c0836b3c)
ata1.00: configured for UDMA/133
ata2.00: configured for UDMA/133
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
scsi 0:0:0:0: Direct-Access ATA WDC WD20EFRX-68E 82.0 PQ: 0 ANSI: 5
NET: Registered protocol family 17
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
UBI: attaching mtd4 to ubi0
******** sd_probe: turn_off LED_HDD1 ********
******** sd_probe: turn_on LED_HDD1 WHITE********
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
sd 0:0:0:0: [sda] 4096-byte physical blocks
scsi 1:0:0:0: Direct-Access ATA WDC WD20EFRX-68E 82.0 PQ: 0 ANSI: 5
******** sd_probe: turn_off LED_HDD2 ********
******** sd_probe: turn_on LED_HDD2 WHITE********
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
sd 1:0:0:0: [sdb] 4096-byte physical blocks
sd 1:0:0:0: Attached scsi generic sg1 type 0
sd 1:0:0:0: [sdb] Write Protect is off
sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1 sda2 sda3
sd 0:0:0:0: [sda] Attached SCSI disk
sdb: sdb1 sdb2 sdb3
sd 1:0:0:0: [sdb] Attached SCSI disk
UBI: scanning is finished
UBI: attached mtd4 (name "RootFS-1", size 106 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 847, bad PEBs: 1, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 596131792
UBI: available PEBs: 0, total reserved PEBs: 847, PEBs reserved for bad PEB handling: 39
mvebu-rtc f10a3800.rtc: setting system clock to 2024-03-06 19:00:17 UTC (1709751617)
Freeing unused kernel memory: 6456K (c081d000 - c0e6b000)
UBI: background thread "ubi_bgt0d" started, PID 1187
eth0: mac address changed
bmPoolId = 0 has unknown buf_size
pool #0: pkt_size=1536, buf_size=1600 - 4096 of 4096 buffers added
egiga0: link up
egiga0: started
egiga0: link down
egiga0: link up, full duplex, speed 1 Gbps
egiga0: link down
UBI: detaching mtd4 from ubi0
UBI: mtd4 is detached from ubi0
UBI: attaching mtd6 to ubi6
UBI: attached mtd6 (name "RootFS-2", size 106 MiB) to ubi6
UBI: good PEBs: 839, bad PEBs: 9, corrupted PEBs: 0
UBI: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 1502973064
UBI: available PEBs: 0, total reserved PEBs: 839, PEBs reserved for bad PEB handling: 31
UBI: background thread "ubi_bgt6d" started, PID 1381
UBIFS: mounted UBI device 6, volume 0, name "ubi_rootfs2", R/O mode
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 100691968 bytes (96 MiB, 793 LEBs), journal size 5079040 bytes (4 MiB, 40 LEBs)
UBIFS: reserved for root: 4755930 bytes (4644 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID F8D55E18-4545-4265-9DFF-94DDED3FC014, small LPT model
md: md0 stopped.
md: bind<sdb1>
md: bind<sda1>
md/raid1:md0: active with 2 out of 2 mirrors
md0: detected capacity change from 0 to 2045706240
md: md1 stopped.
md: bind<sdb2>
md: bind<sda2>
md/raid1:md1: active with 2 out of 2 mirrors
md1: detected capacity change from 0 to 2046754816
md1: unknown partition table
Adding 1998780k swap on /dev/md1. Priority:-1 extents:1 across:1998780k
md0: unknown partition table
EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
EXT4-fs (md0): re-mounted. Opts: (null)
EXT4-fs (loop0): mounting ext2 file system using the ext4 subsystem
EXT4-fs (loop0): mounted filesystem without journal. Opts: (null)
UBI: attaching mtd2 to ubi2
UBI: attached mtd2 (name "Config", size 10 MiB) to ubi2
UBI: good PEBs: 80, bad PEBs: 0, corrupted PEBs: 0
UBI: max/mean erase counter: 61/39, WL threshold: 4096, image sequence number: 1368162132
UBI: available PEBs: 0, total reserved PEBs: 80, PEBs reserved for bad PEB handling: 40
UBI: background thread "ubi_bgt2d" started, PID 1567
UBIFS: background thread "ubifs_bgt2_0" started, PID 1571
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 2, volume 0, name "ubi_config"
UBIFS: FS size: 3301376 bytes (3 MiB, 26 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
UBIFS: reserved for root: 155931 bytes (152 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID BC36300D-4C68-46F2-B4CC-C75F2D6A4724, small LPT model
NTFS driver 2.1.30 [Flags: R/O MODULE].
tntfs: module license 'Commercial. For support email ntfs-support@tuxera.com.' taints kernel.
Disabling lock debugging due to kernel taint
Tuxera NTFS driver 3015.1.29 [Flags: R/W MODULE].
PPP generic driver version 2.4.2
PPP MPPE Compression module registered
PPP Deflate Compression module registered
NET: Registered protocol family 24
PPP BSD Compression module registered
md: md2 stopped.
md: bind<sdb3>
md/raid1:md2: active with 1 out of 2 mirrors
md2: detected capacity change from 0 to 1996168691712
md2: unknown partition table
EXT4-fs (md2): warning: mounting fs with errors, running e2fsck is recommended
EXT4-fs (md2): recovery complete
EXT4-fs (md2): mounted filesystem with ordered data mode. Opts: usrquota,data=ordered,barrier=1
IPv6: ADDRCONF(NETDEV_CHANGE): egiga0: link becomes ready
EXT4-fs error (device md2): ext4_mb_generate_buddy:755: group 11424, 0 clusters in bitmap, 65280 in gd
EXT4-fs error (device md2): ext4_mb_generate_buddy:755: group 12852, 0 clusters in bitmap, 65280 in gd
EXT4-fs error (device md2): ext4_mb_generate_buddy:755: group 14088, 0 clusters in bitmap, 65280 in gd
EXT4-fs error (device md2): ext4_mb_generate_buddy:755: group 14175, 0 clusters in bitmap, 65280 in gd
EXT4-fs error (device md2): ext4_mb_generate_buddy:755: group 2385, 0 clusters in bitmap, 65280 in gd
EXT4-fs error (device md2): ext4_mb_generate_buddy:755: group 6797, 0 clusters in bitmap, 65280 in gd
EXT4-fs (md2): error count: 175
EXT4-fs (md2): initial error at 1551382506: htree_dirblock_to_tree:920: inode 16910944: block 67641718
EXT4-fs (md2): last error at 1709751651: ext4_mb_generate_buddy:7550 -
Well, at least you have some filesystem errors, which can cause the zero byte files. You should run e2fsck on /dev/md2. Unfortunately that is not that simple. Here I wrote about how to get that done. The forum software has b0rked up my code, so you'll have remove the html code around and between the commands. And skip the resize2fs.
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
