How to disable Cloud saving mode
i do not often connect to my nebula dashboard but now there is no way for me to disable cloud native mode, how can i please?
The toggle won't move.
Hi @danielefiore,
Thanks for the detailed information from you. After checking, I found the main reason might be because your account's role is not "organization full" admin. I suggest using the owner account to disable the cloud saving mode or raise your account's role to "organization full" admin.
Zyxel Melen0
Hi @danielefiore,
Could you help to enable Zyxel support for me to check?
Please go to Help (identified by a question mark icon at the upper right corner of Nebula portal) > Support Request > Zyxel support Access to enable and save.Zyxel Melen0 -
hello i have just done it, i do not see the save button though
Hi @danielefiore,
Zyxel Melen0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
