How to disable Cloud saving mode
i do not often connect to my nebula dashboard but now there is no way for me to disable cloud native mode, how can i please?
The toggle won't move.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,593 image  Zyxel Employee
    Hi @danielefiore,
    Thanks for the detailed information from you. After checking, I found the main reason might be because your account's role is not "organization full" admin. I suggest using the owner account to disable the cloud saving mode or raise your account's role to "organization full" admin.
    Zyxel Melen
  • Zyxel_Melen
    Hi @danielefiore,
    Could you help to enable Zyxel support for me to check?
    Please go to Help (identified by a question mark icon at the upper right corner of Nebula portal) > Support Request > Zyxel support Access to enable and save.
    Zyxel Melen
  • danielefiore
    danielefiore Posts: 2
    edited March 2024
    hello i have just done it, i do not see the save button though
  • Zyxel_Melen
    Hi @danielefiore,
    Zyxel Melen
Nebula Tips & Tricks
