It does not work!
Hi @KMarc
It appears that the LAN2 interface is currently in use (referenced) within the VPN settings, which is why it cannot be deleted from your firewall configuration. To resolve this issue, please navigate to "Site-wide > Configure > Firewall > Site-to-Site VPN" and disable the LAN2 interface from the local networks setting. Once this is done, you should be able to remove the interface settings without any problem.
Hi @KMarc
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
