VMG1312-B10D: Using SSID Subnet makes the AP unconnectable (i.e. DHCP does not give IPs)
stdedos
Hello @stdedos
Welcome to the forum.
I think that you might have found a bug, which will not get fixed on the VMG1312-B10D device because that went end of life by Zyxel in about November 2020.
If the software is common to other Zyxel products, then it might get fixed.
Kind regards,
Tony
I … assume I cannot have the source to make my fix and sign my firmware to flash it, right? 😅
"If possible", please let me know of "any future updates".
Thank you for responding 😄
Hello @stdedos
You are welcome.
If you want at your own risk to look at the source code, then you might be interested in looking this thread on the Kitz forum. https://forum.kitz.co.uk/index.php?topic=26923.0
Obviously, you will be doing it at your own risk.
Kind regards,
Tony
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
