PLA6457 not compatible with Devolo Magic 2
My PLA6457s are not compatible with the Devolo Magic 2 WiFi 6, whereas both support G.hn protocol. Is there something specific to set up ?
Thanks for your help.
Hello @Nap75
Welcome to the forum.
Neither of these G.hn devices has been through the HomeGridForum Interoperability testing for G.hn , see https://homegridforum.org/g-hn-home-networking-certification/ and https://homegridforum.org/products-category/powerline-2/
Some Devolo products are listed, but not your model, and no Zyxel products are listed as certified.
So I don't think that they will work together. You might have to buy products from the same manufacturer or ones that have been certified.
Kind regards,
Tony
Hello @tonygibbs16 ,
Thanks for your reply. The devolo product is listed :
But not the Zyxel product. But Zyxel claims that this product is G.hn compliant in its datasheet : https://download.zyxel.com/PLA6457/datasheet/PLA6457_1.pdf
Forget it. They are fully compatible. I'm just stupid. You just need to reset both of them in order to restart a pairing session from scratch as they need to be on the same G.hn network.
2
- 415 Beta Program
- 2.4K Nebula
- 151 Nebula Ideas
- 98 Nebula Status and Incidents
- 5.7K Security
- 278 USG FLEX H Series
- 277 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.4K Consumer Product
- 250 Service & License
- 395 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
