NWA90AX Pro mac address filtering
Hi @mwyser ,
To ensure that only certain MAC addresses clients can connect to your Access Point (or SSID), you can implement one of the following two secure methods:
- MAC-based Authentication: This method permits only devices with MAC addresses that are included in the Access Point's MAC address list to connect to the Wi-Fi network. For detailed instructions on how to set this up, please consult the relevant FAQ section.
[NEBULA] How to control and secure network access with MAC-based Authentication? — Zyxel Community
- Client policy (MAC filter): This function is used to do MAC filter for the stations. We can add the station into whitelisted called “Allow list” which can bypass the Captive portal, add into “Block list” which will be blocked to access the SSID, and "To specific SSID" allow to connect specific SSID. For step-by-step guidance on implementing client policy feature, please refer to the appropriate FAQ section.
[NEBULA] How to control and secure network access with client policy (MAC filter)? — Zyxel Community
Zyxel_Judy
Hi @mwyser ,
Zyxel_Judy
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
