NSA325 degraded RAID1 after replacing HDD "impossible" to repair.
Hi everyone.
I bougth the NSA325 NAS some 10+ years ago. At first I used 2 HDD, 2TB each, in RAID1. Let's call them VeryOld1 (VO1) and VeryOld2(VO2), model ST2000VN000. 3 years ago, VO2 stopped working, so I replaced it with a new HDD, called Old1 (O1), 4TB, model ST4000VN008. I just put it in the bay, turned on the NAS, the system recognized a degraded RAID1, repaired it, and I got myself a fully functional 2TB RAID1 system again.
Few weeks ago, I bought a new HDD, 4TB, model ST4000NE00 - New1 (N1). The idea was to remove VO1, put in N1 with O1, rebuild the RAID1 and expand the volume to 4TB. Please note both VO1 and O1 are perfectly fine, according to SMART.
First (1: O1+N1) attempt: it failed. RAID was not even degraded, but DOWN. No access to the content from exported shares. After few tries, I turned off the NAS, removed N1, put back in VO1, and turned on (2: VO1+O1). The system recognized a DEGRADED RAID1, but failed to repair it. I had access to the content via NFS export.
I checked online but was not able to repair it. So I made another attempt: keep VO1, remove O1, put in N1. (3: VO1+N1).
System found a degraded RAID, and repaired! VO1 and N1 working.So I thought I had it. Turned it off, removed VO1, put in O1 instead. (4: O1+N1): RAID DOWN. Same result as (1).
I sweared, removed O1, put back in VO1. Same configuration as (3), that was working fine: RAID DEGRADED. Repair failed.Sweared again.
Now I'm with O1+V1. The system sees only disk2 in RAID. I'm attaching a few outputs.
Can anyone help me? I guess there is something wrong with the partitions (or with my head…). I thought of formatting O1, try to rebuild the RAID with VO1+O1 and, if it works, format N1, rebuild the RAID with VO1+N1, and finally try to put together O1+N1. But I really hope there is a smarter way…
Cheers,
Paolo
mdadm --detail /dev/md0
/dev/md0:
Version : 1.2
Creation Time : Fri Jan 10 14:46:48 2014
Raid Level : raid1
Array Size : 1952996792 (1862.52 GiB 1999.87 GB)
Used Dev Size : 1952996792 (1862.52 GiB 1999.87 GB)
Raid Devices : 2
Total Devices : 1
Persistence : Superblock is persistent
Update Time : Mon Mar 18 17:47:50 2024
State : clean, degraded
Active Devices : 1
Working Devices : 1
Failed Devices : 0
Spare Devices : 0
Name : NSA325:0 (local to host NSA325)
UUID : c37b646d:3f15bc83:6dbb0bd8:bc6152d8
Events : 11894640
Number Major Minor RaidDevice State
0 0 0 0 removed
2 8 18 1 active sync /dev/sdb2
fdisk -l
Disk /dev/sda: 2000.3 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0xxxxxxx9
Device Boot Start End Blocks Id System
/dev/sda1 1 64 514048+ 8 AIX
/dev/sda2 65 243201 1952997952+ 20 Unknown
Disk /dev/sdb: 4000.7 GB, 4000787030016 bytes
255 heads, 63 sectors/track, 486401 cylinders
Disk identifier: 0xxxxxxxc
/dev/sdb1 1 64 514048+ 83 Linux
/dev/sdb2 65 267349 2146966762+ 20 Unknown
mdadm --examine /dev/sd[ab]2
/dev/sda2:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : c37b646d:3f15bc83:6dbb0bd8:bc6152d8
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 1952996928 (1862.52 GiB 1999.87 GB)
Data Offset : 2048 sectors
Super Offset : 8 sectors
State : clean
Device UUID : d4e91f24:03a4c98f:7e4ad766:d3ce6ad0
Update Time : Sun Mar 17 16:37:53 2024
Checksum : 246c25ce - correct
Events : 11890526
Device Role : Active device 0
Array State : AA ('A' == active, '.' == missing)
/dev/sdb2:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 2146965738 (2047.51 GiB 2198.49 GB)
State : clean
Device UUID : f488f869:d666e828:7fc1e4bb:9a493b90
Update Time : Mon Mar 18 17:48:15 2024
Checksum : 2f6360ef - correct
Events : 11894642
Device Role : Active device 1
Array State : .A ('A' == active, '.' == missing)
That's weird. I see no real reason why this wouldn't work. I wouldn't expect the 'Avail Dev Size' to be different on both disks. The new one is supposed to be a clone of the old one, including partition table. But AFAIK this shouldn't be a problem for the raid array.
You won't be able to enlarge this array to 4TB, when you manage to get 2 4TB disks in sync. The partition table is MBR, which means it can't define partitions >2TB. When you start over, (and wipe the current partition table?) it should create a GPT partition table, which allows bigger partitions.
Hi Mijzef, thanks a lot. I'm puzzled as well. I'm taking the proper set of actions is:
- Leave only N1 (new 4TB) in the NAS. Delete volume/reset HDD (Would it be better to do it from terminal? which command do you recommend? Or it would even better to recreate manually the proper partions? How?)
- Put again VO1 (very old 2TB) in the NAS with the "emptied" N1
- Rebuild RAID (hopefully it works… at this point, how can I check the partition has been recreated as GPT in N1?)
- Remove both, insert only O1 (old 4TB) . Delete volume/reset HDD (same as point #1)
- Insert N1 with O1
- Keep fingers crossed
If this doesn't work… Move VO1 in the PC, mount it, put O1 and N1 in the NAS, delete volume, create a "clean" 4TB RAID1, copy from VO1. Maybe it could be even faster like this, but I'm worried I could loose all the groups, shares, exported and so on…
What do you think?
Cheers, Paolo
AFAIK the firmware is supposed to clone the partition table of the remaining raid member. So when doing your 1,2 strategy disk N1 will not get a GPT.
I think the best approach is to put only N1 into the box, wipe the partition table
dd if=/dev/zero of=/dev/sda bs=1M count=1
reboot, to get the non-existing table active, then create a single disk raid1 array. You can see if it's GPT as the volume is >2TB.
Then insert VO1, with some luck it will be recognized and mounted as degraded array. Copy your files over to the array on N1. Better use the file browser or command line, using Samba will down- and upload everthing.
And finally insert O1 and add it to the single disk raid1 array, making it redundant.
There might be a problem, if you are using ssh now, you will loose it as soon as you pull the current volume. The ssh server is an installable package, and is installed on that volume. So you'll have to use the telnet backdoor instead.
Hi, thank you again. There is just 1 thing that worries me. VO1 is the only disk I'm able to use to retrieve data from (in the NAS). If i put only O1, N1 or both, I'm not able to retrieve data from interface or export. No folders or anything. RAID is DOWN, Disk Usage = N/A. There are no active packages and such.
I'm worried that, if I insert VO1 within the newly rebuilt N1, I could loose the content of VO1. I Backed up most of the important stuff, but don't have room enough for everything. "with some luck" sounds ominous to me 😁
Also, I'm guessing I'd loose groups, shares, NFS exports… is that correct?
In the meantime, I started what you suggested:
1+0 records in
1+0 records out
1048576 bytes (1.0MB) copied, 0.005526 seconds, 181.0MB/sRestarted, and there are no volumes. But I can't create a single disk RAID1 array, only JBOD is available
I created a JBOD volume just to be sure: 3,58 TB.
No packages available (and retrieve from internet is not working; but it was to be expected, I found your old posts about this).
Not sure how to proceed further.
Sorry for the flooding of question and doubts and having you guide me step by step.
I suppose somehow the raid manager chokes in O1 and N1. If you plugin O1 next to N1, you can try to assemble and mount the array manually.
Assuming O1 is sdb, the commands to do so are:
mdadm -A /dev/md1 /dev/sdb2 —run mkdir /tmp/mountpoint mount /dev/md1 /tmp/mountpoint
Now you should be able to see your data in /tmp/mountpoint
ls /tmp/mountpoint/
It is possible that the firmware dives in and moves the mountpoint. In that case you should be able to see it in the filebrowser and/or sambe shares.
You can check if the disk is sdb with
cat /proc/partitions
if sdb2 is around 2TB and sda2 around 4TB, sdb is O1. Else it's N1
The packages are installed in the data volume. So if the array is down, there are no packages.
Yeah. That was about the automatic assemble&mount. Manually should always be possible.
Correct. Although the shares are on certain level just directories, and that directories can be copied. Then you can re-activate them as share. But owner, access rights and such are gone.
About groups I'm not sure. The user config is stored on a flash partition, so that might survive a volume change. But maybe it invalidates if the volume changes.
Don't know exactly what JBOD is. Have a look with mdadm, I think it's just a single disk raid1
mdadm -E /dev/md0
Hi Mijzef, thanks a lot again, and sorry for the long delay.
JBOD = Just a Bunch Of Disks, kind of similar to RAID 0.
In the meantime, I reverted to VO1 and O1, with a 2TB "healthy" RAID1. Reason is, I have a very limited amount of time available as per now. I'm almost sure I can create a "blank" 4TB RAID1 and then copy the data, thanks to your help, but I'd also need to config the metarepository, install packages, create shares, users, groups, exports… I can't afford it as per now 😅
Unless: there is a way to export most of the config files? E.g. the NFS export are in /etc/exports and such.
As far as I remember there is an option in the webinterface to ex- and import user settings. But maybe that is only on the firmware 5 devices.
- 441 Beta Program
- 293 Service & License
