VMG8823-B50B, V5.13(ABOV.0) how to setup DuckDNS settings
Dino2
I need help to configure the modem VMG8823-B50B, V5.13(ABOV.0)b1_20180824 from Tiscali,
to activate the DNS as "DNS user defined".
Actual settings: (not working)
- "Tipo di connessione:" (connession type), tested both HTTP and HTTPS
- "URL di aggiornamento:" (URL to be updated) here used:
https://duckdns.org/update/my domain/mytoken
or
https://www.duckdns.org/update?domains=mydomain&token=mytoken
notice that both strings return an OK when sent via my browser ( the IP is updated).
- "Nome dispositivo ospite" (guest device name?), used http://mydomain.duckdns.org
- "Nome Utente" (username) any string, not requested by duckdns.org
- "Password" any string, not requested by duckdns.org
Notice that both username and password are requested by modem application page.
Thanks for your advice
Dino
#SP_May_2019
Hey, did you manage to make DuckDNS work with a Zyxel router?
I managed like this:
User Provider: DNS user definedConection type: http
Update URL: www.duckdns.org/update/domain/token
host name: domain.duckdns.org
username: a
password a
Result:
Estado DNS dinámico
Resultado de autentificación del usuario: Accepted
Tiempo de la última actualización: Jan 25 15:30:45
IP dinámica actual: 79.116.35.XXX
Hello @gunspin Setting up DuckDNS on the VMG8823-B50B can be complicated, but following the correct configuration steps, you can ensure your device is always accessible without interruption!
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
