IP static reservation on DHCP client
Zyxel_Nami
Zyxel_Nami Posts: 659 image  Zyxel Employee
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
edited July 2024 in Nebula Ideas
User @vining proposes that IP static reservation on DHCP client in NCC.
If anyone likes this idea, please feel free to leave a comment or click vote.
Original post
Nami
11 votes
Active · Last Updated
  • ZyxelTri
    ZyxelTri Posts: 1 image  Freshman Member
    Zyxel Certified Sales Associate First Comment Second Anniversary
    This should be allowed in the Client view. Right now for SCR50AXE as the router, it only lets you use the drop down menu to reserve the IP if it's directly connected to the router, but if there is a switch in between that is Nebula managed, it does not allow for reservation. But if you put a 3rd party or unmanaged switch in between, then it does allow to reserve. We need both and any firewall to have ability to reserve through the client view, and manually assigned and can be edited in that reserve window.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @ZyxelTri
    Thank you for your feedback.
    Clients under the Nebula management switch can reserve an IP address from the client page on SCR device.
    If you still have the issue, to check the issue, please turn on support requests.
    Here's a guide on how to turn on support requests on Nebula.
    Best Regards,
    Jerry
Nebula Tips & Tricks
