Can't install SMB V2 on NSA325
It's the Network discovery side, where it will show all computers and devices on the network which have shares.
If I put back SMB 1.0/CIFS File Sharing Support , it then works, but Win11 etc as you know, that should be disabled now, hence going to SMB2.Is it possible SMB2 on the NAS hasn't worked?
I think we are misunderstanding each other. It is possible network discovery won't work for SambaReplacement. But access should work. If you enter \\<ip-of-nas>\<sharename> in the address bar of explorer, the share should be opened.
Depending on your network setup \\<name-of-nas>\<sharename> could also work. But in that case your local DNS does the name resolving, and not the Windows network discovery.
- 441 Beta Program
- 534 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
