N-4100 used as a secondary router
I have a password protected D link connected to my xplornet modem.. Is it possible to connect via ethernet cable, from a lan port on the d-link router, to the wan port on my zyxel N-4100 router.. Which in turn is in turn set to non-authentication, but allows numerous connections to the internet, but yet allows me to control the speeds to the users..
If possible what changes would In have to make? Please reply also to johnny1000@rocketmail.com Thanks
I think can connect dlink and zyxel router via ethernet cable. But you may need to change some settings on both devices.
The N-4100 does have the ability to add a password, but it only works on one transmitter connected to a LAN.. Tonight I tried connecting my D-link router, to the xplornet modem, as my d link has a password.. Then I ran a line from a Lan connection on the Dlink router, to the WAN connection on my N-4100.. I was hoping it would work, that if people went to sign in via my N-4100, it would echo back to the Dlink router, then ask for the password of the router, before allowing access to the non authenticated N-4100.. Sadly, the access through the xplornet modem, would not allow the signal to go through the N-4100
- 441 Beta Program
- 293 Service & License
