ZyXEL NAS 326 - cannot install new SSL certificate for https
Hello. Last year, following the instructions at https://mysupport.zyxel.com/hc/en-us/articles/360006916979--NSA-NAS-How-to-fix-certificate-error-on-browser-when-accessing-NAS-WebUI
I was able to install a certificate to my NAS. I have a public IP address with a DNS record which then I forward to an internal IP. It worked perfectly after removing everything at /etc/zyxel/cert except for the new certificate renamed to default.cer and key/default_key.cer.
Being almost expired, I renew the certificate and follow the same procedure as last year. The problem is that the certificate and key file are rewritten every reboot, and the NAS keeps using a new self signed certificate each time. I may have upgraded the firmware during last year (currently running V5.21(AAZF.15).
Was there any change in the procedure to install a certificate?
Also, I was trying to manual upgrade to latest V5.21(AAZF.16)C0, and after 2 reboots, it still shows the previous firmware version ?!
Thanks and regards.
Ok, so I have a solution but it won't allow me to access SSL configurations through Control Panel.
I had to copy my CSR.p10 again to /etc/zyxel/cert. I had removed it from there because last year I had to erase all files except default.cer and default_key.cer (under the folder named "key").
Then I can access the SSL web interface and import the signed certificate. The NAS then restarts the network and in the meantime I could confirm the new CA.cer and CA_key.cer in /etc/service_conf/ are my certificates. Now I have valid certificates, the only problem is I can't acces SSL configurations in Control Panel. I had this problem last year and solved it by removing all files under /etc/zyxel/cert and leaving just my certificate and key renamed to default.cer and default_key.cer.
I've also tried this, but If i do, after a reboot the certificates are generated again under /etc/service_conf and /etc/zyxel/cert.
So, if no one has a better idea, I'll leave it for now.
Regards.
Long shot. Do you still have the old certificate, and can you compare it with the new one? I wonder if some new Signature Algorithm or something like that is used, which is not supported by the aging webserver on the box.
Thanks for the reply. Unfortunately, the new one is the same type and size.
Checking /etc/init.d/httpd.sh I found the script checks for existing /etc/service_conf/CA.cer and CA_key.cer. If they do not exist, it copies them from /etc/zyxel/cert.
I overwrote both certificate and key at these two locations, rebooted, but nevertheless they are rewritten upon reboot.
Any ideas, please?
When you copy the files to /etc/zyxel/cert/, can you run dmesg after that to see if there are filesystem errors on that flash partition?
I'm sorry, but didn't find anything related in dmesg after copying the certificate and key.
Nevertheless, I've found:
EXT4-fs (md2): error count: 208
EXT4-fs (md2): initial error at 1574712239: ext4_mb_generate_buddy:755
EXT4-fs (md2): last error at 1711109576: htree_dirblock_to_tree:920: inode 156311586: block 1250431372
EXT4-fs error (device md2): htree_dirblock_to_tree:920: inode #156872721: block 1254626161: comm python: bad entry in directory: rec_len is smaller than minimal - offset=2664(10856), inode=0, rec_len=0, name_len=0
EXT4-fs (md2): error count: 209
EXT4-fs (md2): last error at 1711622074: htree_dirblock_to_tree:920: inode 156872721: block 1254626161
EXT4-fs (md2): last error at 1711622074: htree_dirblock_to_tree:920: inode 156872721: block 1254626161But I'm not sure if this was after I copied the file.
Yeah. It's nice that the kernel is compiled to not use timestamps here. I don't think this has to do with your problem. /dev/md2 is the data partition, that shouldn't be involved in certificate actions. Yet it's not a good idea to have filesystem errors there, of course.
I did a grep on my 520. The file /sbin/zyshd seems responsible for generating the new certificate:
/etc/zyxel/cert/
CA.cer
/etc/zyxel/cert/key/
CA_key.cer
CSR_key.p10
default.cer
default_key.cer
/etc/service_conf/
%s x509 -inform %s -in %s -outform PEM -out %s
/usr/bin/openssl
%s "%s" "%s"zyshd is the binary which is responsible for all nas management in background. It generates and edits configuration files in /etc (which is on a ramdrive, and thus volatile). So apparently something triggers it to generate a new certificate on boot.
Did you actually look inside the file? An x509 certificate is a textfile.
Have you checked if the webserver actually can use your new certificate by manually restarting it after copying the files to /etc/service_conf/? If yes, a work around could be possible by automatically copying the files from elsewhere and restarting the webserver.
Run e2fsck -n /dev/md2 and rebooted.
Now dmesg only shows:
EXT4-fs (md2): last error at 1711622074: htree_dirblock_to_tree:920: inode 156872721: block 1254626161after the reboot, both certificates at /etc/zyxel/cert and /etc/service_conf were recreated :(
Thanks for the reply. My NAS326 doesn't have a /sbin/zyshd . I didn't know /etc/zyxel was volatile…interesting.
As for the certificates, they are exactly as they intended: I had checked them already with
openssl x509 -in…The DNS name is ok, it is the same type as the self generated but 2048 bits instead of 4096 as the self generated( I wrote this wrongly on a previous post). The previous I used last year was also 2048, so I don't think this should be an issue. The problem is that there are several /etc/init.d/ http related scripts. After I kill them all I wasn't able to successfully start http again.
After stopping httpd with /etc/init.d/httpd.sh stop I can't start it again. Also tried to stop pkghttpd.sh and davhttpd.sh and then httpd.sh but still no result. Couldn't find documentation yet about starting these processes manually.
Http related processes before trying a /etc/init.d/httpd.sh restart
/etc/zyxel/cert # ps | grep http
2533 root 9888 S /i-data/.system/zy-pkgs/pkg_httpd -f /etc/pkg_service_conf/httpd2.conf
2637 nobody 11544 S /i-data/.system/zy-pkgs/pkg_httpd -f /etc/pkg_service_conf/httpd2.conf
2638 nobody 11544 S /i-data/.system/zy-pkgs/pkg_httpd -f /etc/pkg_service_conf/httpd2.conf
3404 root 10416 S /sbin/DAV_httpd -f /etc/service_conf/httpd_dav.conf
3495 root 12056 S /sbin/DAV_httpd -f /etc/service_conf/httpd_dav.conf
3496 root 12056 S /sbin/DAV_httpd -f /etc/service_conf/httpd_dav.conf
3701 root 9892 S N /usr/sbin/httpd -f /etc/service_conf/httpd.conf
3789 nobody 22436 S N /usr/sbin/httpd -f /etc/service_conf/httpd.conf
5666 nobody 11544 S /i-data/.system/zy-pkgs/pkg_httpd -f /etc/pkg_service_conf/httpd2.conf
5675 nobody 11544 S /i-data/.system/zy-pkgs/pkg_httpd -f /etc/pkg_service_conf/httpd2.conf
5713 nobody 22424 S N /usr/sbin/httpd -f /etc/service_conf/httpd.conf
7432 nobody 22412 S N /usr/sbin/httpd -f /etc/service_conf/httpd.conf
10393 nobody 22412 S N /usr/sbin/httpd -f /etc/service_conf/httpd.conf
11631 nobody 11412 S N /usr/sbin/httpd -f /etc/service_conf/httpd.conf
13299 root 2656 S grep httpAfter the restart, I get fewer processess. Admin page not working but /MyWeb/shares do:
killall: httpd: no process killed
13392 root 2656 S grep httpwhy would httpd not restart? I've tried running manually the commands that are in httpd.sh.
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 307 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
