DX3301-T1 firmware
diegoemy76
diegoemy76 Posts: 8
edited August 2023 in Home Router
hi my isp sent me this router but I can't completely find a firmware nor info about it.. I was wondering if anyone has a firmware for this device I tried to load the firmware of the zyxel dx3301-t0 but it doesn't work. .. .. I need it because maybe during an update of my isp the power went out now it's in boot loop I can only send firmware via tftp but I can't completely find it and my isp hasn't given me an answer about it
«1
  • diegoemy76
    diegoemy76 Posts: 8
    edited August 2023
    i also have a usb to uart just in case.. i'm available to be a beta-tester
  • no one ?????
  • Peter2
    Peter2 Posts: 141  Ally Member
    You mean DX 3300-T1 i think :
    »»» May be you can try to disable the parameters "modelcheck" and "fwidcheck" via ssh to allow firmware upgrade when the cause is e.g. special ISP firmware version over web gui like below :
  • diegoemy76
    diegoemy76 Posts: 8
    edited March 2024
    I tried but it gives me kernel panic
  • Peter2
    You give no info which firmware version is yours and when and where "kernel panic" is shown .
    May be you can try beginning with the older firmwares and then the newer 3.1 , 3.4 and then 4.0 are available downloads .
    The current firmware for the dx3301-to is correct for 3300-T1 .
  • DX3301-T1 (V5.50(ACDU.1)b7_E0_20230703) is the firmware version KERNEL panic shows during boot
  • Peter2
    edited March 2024
    So you are locked out now ? As a result of doing what ?
    The Tip above is changing the parameters descripted and the make the normal firmware upgrade over gui . If this really happens we can give out a warning ?
  • Simply tried stock firmware but no one is working with this devices
  • Peter2
    "Simply tried stock firmware" what does it mean ? You did things you dont really know and not having experience with ?
  • This is not the first time ..I flashed a ton of zyxel devices this device is the only one that do not accept any of the firmware .. even it's brother dx3301-t0 I asked for a firmware not a lesson on firmware flashing if you can't provide it .. do not post useless comment
