LTE3316 How do I use it with a VPN? - URGENT
Hello @DWARD
Thanks for your reply. Yes it is v1 of the user guide, but it does not say that it is hardware version specific.
What firmware version is your device running please?
* Your latest screenshot was very helpful, as it seems like your device is running a version of firmware without showing the Configuration menu at all. An ISP customised firmware version.
Kind regards,
Tony
Thank you. You mention ISP customised. I purchased this myself new from Amazon and there is no mention of it being ISP customised. Attached is a screenshot, that firmware is the latest that it says there is
Hello @DWARD
You are welcome.
Your latest screenshot shows that your LTE3316-m604 device is running a customised version of firmware, because the firmware name does not end in C0 after the brackets.
This explains why you cannot see the Configuration menu, because someone has changed the firmware build.
I am not sure of the easiest way to get to your device onto the non-customised firmware line-up.
You probably need to log a trouble ticket with Zyxel using the following link. https://support.zyxel.eu/hc/en-us/requests/new?ticket_form_id=114093996354#
Or you might want to ask the Amazon seller for a return and refund.
Kind regards,
Tony
Just to chip on this, I was looking to run a VPN from my LTE3316-M604 which is running
firmware:- 2.00(ABMP.7)C0 (ie latest stock firmware) and I too cannot see any of the options to get to VPN settings referenced in the above trail…
On the official Zyxel support page for the 3316 there are 2 versions of the datasheet for the spec.
1 has VPN listed, 1 doesn't…
2019 spec
https://download.zyxel.com/LTE3316-M604/datasheet/LTE3316-M604_2.pdf
2021 spec
https://download.zyxel.com/LTE3316-M604/datasheet/LTE3316-M604_3.pdf
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
