Updated NAS 326 firmware - Now web management interface no longer works.
I just applied V5.21(AAZF.16)C0 to my NAS 325 and it rebooted correctly, then the SMB and NFS shares came up ok, but the management web interface is not working anymore…
If I go to it by IP address or local name neither works in the browser. This is the URL it tries to redirect to:
http://192.168.1.65/r51277,/desktop,/index.html
Note the commas in the URL. Is that normal? Any ideas?
Thanks in advance!
Mike
That comma is normal. Every firmware release has it's own 'r number'. I think it's the revision number of the source version control. In most cases when the webinterface is not reachable after a firmware update, it's due to a cached redirect, which now redirects wrong. So try to clear your cache, or use a private window.
Hi Mijzelf,
I cleared ALL my browsing history, cookies, etc. When I type in the address (http://192.168.1.65/) no redirect occurs and this is what I get…
Thanks in advance for any help.
Mike
Also, just did a port scan and port 80is no longer open:
Starting Nmap 7.94SVN ( https://nmap.org ) at 2024-03-26 13:48 CDT
Nmap scan report for NAS326.local (192.168.1.65)
Host is up (0.00024s latency).
Not shown: 65521 closed tcp ports (conn-refused)
PORT STATE SERVICE
111/tcp open rpcbind
139/tcp open netbios-ssn
445/tcp open microsoft-ds
548/tcp open afp
2049/tcp open nfs
5000/tcp open upnp
5001/tcp open commplex-link
9001/tcp open tor-orport
9002/tcp open dynamid
35158/tcp open unknown
36711/tcp open unknown
36934/tcp open unknown
39171/tcp open unknown
41331/tcp open unknown
MAC Address: BC:99:11:15:F1:92 (Zyxel Communications)0 -
- - Slope Game -
Ensure that the IP address and local name you're using to access the NAS 325 are correct. Double-check the network settings on your NAS to ensure there are no conflicts or misconfigurations.
Thanks,
They are correct and I have no way to check the network setting without the web interface. Again, everything is working except the web interface.
Also, just went to
and it shows my device as paired but when I try and sync anything it times out.Any helpful assistance will be appreciated.
Mike
I did a factory reset and was able to get back in after that. Thanks for everyone's help.
Mike
- 435 Beta Program
- 176 Nebula Ideas
- 424 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
