ZTE 5103e 5G issue Germany
Borsvel_3
Good day,
I hope you can help me.
I have two Zyxel 5103e 5G routers with 3 branding.
Both only use LTE when in use and I can't understand it. Why is that?
I have two o2 unlimited Max tariffs. On my Xiaomi 11T pro and my ZTE 801a 5G router I can easily use o2 5G standalone on band n28 with 700MHz. However, not on the two Zyxels, which supported 5G standalone on n28. I can rule out a weak 5g signal. Telekom 5G NSA works without any problems. I use the latest b15 Firmware and it does not matter if i select the Band use only 5G standalone or have everything on auto. Both Routers wont connect. I have a friend having same issues with that model.
Cheers, Henrik
For this kind of issue, it would be better to report this issue to 3.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
