Is there a way to migrate users and shares from NAS320 to NAS542?
parapente
parapente Posts: 2 image  Freshman Member
I have found the configuration by connecting as root to both devices and I have already tried recreating /etc/samba/smb.conf, /etc/samba/smbpasswd, /etc/passwd, /etc/shadow, /etc/group but they are reset after a reboot.
Is there a way to make the config persist or any other way to sync the users and shares between the two devices?
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Al files/directories in /etc/ are on a ramdrive (with exception of the contents of /etc/zyxel/, which is a flash partition), and so volatile.
    A NAS320 doesn't exist. At least not from ZyXEL. Do you mean an NSA320 or an NAS326? In the latter case I think you can copy /etc/zyxel/ugs_conf.db, which contains user and shares configuration. It's a text file containing database commands, you may have to edit it to change the volume name containing the shares.
    When it's an NSA320 I don't know if that ugs_conf.db file exists, and is compatible. But you can have a look.
  • parapente
    Thank you Mijzelf for the answer. Indeed it is a NSA320S nas storage and unfortunately it doesn't have a ugs_conf.db file that I can use.
