Subnet Routing NR5101
Hi - I’ve a question regarding a subnet. My NR5101 is connected to a 2nd Router via LAN Kabel. That 2nd router has a 2nd nic to a 2nd subnet.
According to the documentation I should enable the routing towards that 2nd gateway by simple adding a rule like this :
192.168.100.0 / 255.255.255.0
Gateway:192.168.1.10 (2nd router that knows the 100’ subnet und is connected and in the same subnet as the Zyxel.
The Zyxel UI tells me: wrong ip. Which refers to the “0” I can only add a dedicated IP and not a whole subnet.
So how to set the gateway for a whole subnet?
Can you screen shot the Wrong IP error message?
To set the subnet for NR5101 you can set 192.168.1.1 mask 255.255.255.0
Then 2ng router will get the IP on 192.168.1.X and your 2nd router is 192.168.100.1 and mask 255.255.255.0.
Where did you set 192.168.100.0 / 255.255.255.0??0 is not the IP, you can only set 192.168.100.1 for 2nd router's subnet.
How can I run? the social interaction of a candy clicker 2 or the cerebral challenge of a puzzle game.
-1 -
aHello @Tobi82 ,
I think that you need to give your 2nd router 2 IP addresses.
One on the 192.168.1.x subnet connected to your NR5101, e.g 192.168.1.2 with a 255.255.255.0 subnet mask.
Then on your 2nd router's 2nd Nic, give it an IP address such as 192.168.100.1 with a 255 255 255.0 subnet mask.
If you use these example IP addresses then you would then need to add a static route 192.168.100.0 with subnet mask 255.255.255.0 next hop 192.168.1.2
I will need to look at the manual to find where in the NR5101 UI to set this route up, but see below:
and
and
from
I think that you can set-up a static route in your LAN side as shown in the 2nd and 3rd extracts above, so that you could tell your NR5101 how to get back to your 192.168.100.x network via your 2nd router.
* by following the example in the user guide.
I hope that this is helpful.
Kind regards Tony
- 426 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 5.9K Security
- 343 USG FLEX H Series
- 288 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 404 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
