[solved][VMG8825-T50] Unable to connect a machine
I've got a new modem-router (VMG8825-T50, firmware V5.50) and I've got an issue.
One of my computer doesn't appear in the UI. But I can reach it in SSH, Webdav or by mounting a samba share. It slow but it works.
This computer run Proxmox and two VM. None of these two VM can be reach.
Do you have an idea about this issue ?
Thanks.
Hello @Tredok
Welcome to the forum.
Which version of v5.50 do you have please?
V5.50(ABOM8.3)C0 is the latest firmware available (dated March 2024) to download at https://www.zyxel.com/uk/en-gb/support/download?model=vmg8825-t50k
Kind regards,
Tony
Thank you !
I was in 8.2. I've updated in 8.3.
Same probelm :/
I've an update. This morning, I've try to obtain the VM list. Proxmox give me an error which help to solve some things by editing /etc/hosts.
Now, I can access to GUI of my Proxmox machine, but it is not recognize in Zyxel UI. The VM are up, but they haven't access to Internet.
I suspect a problem with my Proxmox configuration, are you agree with me ?
New update.
The problem with the VM is solved. A service was down. There is still a problem with my Promox machine : it is not detected by my modem-router but works.
Do you think it is important ?
- 415 Beta Program
- 2.4K Nebula
- 151 Nebula Ideas
- 98 Nebula Status and Incidents
- 5.7K Security
- 277 USG FLEX H Series
- 277 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.4K Consumer Product
- 250 Service & License
- 395 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
