[solved][VMG8825-T50] Unable to connect a machine
Tredok
Tredok Posts: 4
edited April 2024 in Home Router
I've got a new modem-router (VMG8825-T50, firmware V5.50) and I've got an issue.
One of my computer doesn't appear in the UI. But I can reach it in SSH, Webdav or by mounting a samba share. It slow but it works.
This computer run Proxmox and two VM. None of these two VM can be reach.
Do you have an idea about this issue ?
Thanks.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @Tredok
    Maybe not an issue if the connectivity is all working.
    Kind regards Tony
  • tonygibbs16
    edited April 2024
    Hello @Tredok
    Welcome to the forum.
    Which version of v5.50 do you have please?
    V5.50(ABOM8.3)C0 is the latest firmware available (dated March 2024) to download at https://www.zyxel.com/uk/en-gb/support/download?model=vmg8825-t50k
    Kind regards,
    Tony
  • Tredok
    Tredok Posts: 4
    edited April 2024
    Thank you !
    I was in 8.2. I've updated in 8.3.
    Same probelm :/
  • Tredok
    Tredok Posts: 4
    I've an update. This morning, I've try to obtain the VM list. Proxmox give me an error which help to solve some things by editing /etc/hosts.
    Now, I can access to GUI of my Proxmox machine, but it is not recognize in Zyxel UI. The VM are up, but they haven't access to Internet.
    I suspect a problem with my Proxmox configuration, are you agree with me ?
  • Tredok
    Tredok Posts: 4
    New update.
    The problem with the VM is solved. A service was down. There is still a problem with my Promox machine : it is not detected by my modem-router but works.
    Do you think it is important ?
  • tonygibbs16
    Hello @Tredok
    Kind regards Tony
  • I've an update. This morning, I've try to obtain the VM list. Proxmox give me an error which help to solve some things by editing /etc/hosts.
