firmware NWA130BE
GePo
GePo Posts: 1
edited April 2024 in Nebula
Where can I get latest firmware for NWA130BE
«1
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,127  Zyxel Employee
    Hi @GePo ,
    As of now, the latest firmware version for the NWA130BE, 675ACIL0C0 is available here for download.
    The firmware will be added to the Zyxel Download Library within the next day.
  • Chris888
    Chris888 Posts: 46  Freshman Member
    First Comment Friend Collector First Anniversary Community MVP
    Judy, is it possible to install a "local" file into cloud managed devices? I don´t find a way in GUI (Nebula). Thanks!
  • Zyxel_Judy
    Hi @Chris888 ,
    The NWA130BE can be updated to the latest firmware via Nebula in the coming days. If you prefer to update immediately, please follow these instructions:
    Using ZON:
    Using FTP:
  • Chris888
    Judy, thanks in advanced! FTP works fine for me!
  • TLG
    TLG Posts: 24  Freshman Member
    Still not seeing the firmware for download on Zyxel Download Library.
  • Chris888
    Try link and update over FTP…very easy…
  • Zyxel_Judy
    edited April 2024
    Hi users,
    As of the latest update, to upgrade the firmware of the NWA130BE in standalone mode to version 675ACIL0C0, follow these steps: navigate to Maintenance > File Manager > Firmware Package, click 'Check Now', and then select 'Upgrade'.
    Alternatively, you can use the bin file provided and upgrade via ZON or FTP.
    The 675ACIL0C0 firmware and release notes for the NWA130BE will be available in the Zyxel Download Library shortly.
    When managing the NWA130BE via the Nebula cloud, you have the option to upgrade the firmware immediately or schedule it at your convenience. To access this feature, navigate to: Configuration > Firmware Management.
  • Chris888
    Download is available now. But why the changelog is empty? Is it a secret or do you have to gues?
  • Zyxel_Judy
    Hi @Chris80 ,
    It appears you are referring to the "Organization-wide Management > Change Log" section. This feature provides logs for any manual changes made to the configuration settings. For example, if you change the SSID name from "Zyxel_Demo" to "Zyxel_Demo_5GHz" or adjust the radio setting for bandwidth from 80 MHz to 40 MHz, these modifications will be documented here.
    Please note that changes made automatically by the access point, such as channel adjustments by DCS, will not be recorded in Change Log section. To view logs for automatic changes, you can navigate to "Monitor > Access Points > Event Log."
  • Chris888
    Judy, i‘m talking about the release notes….they are empty.
Nebula Tips & Tricks
