Whether FWA510 supports VLAN grouping?
I'm a little confused…
I need a 5G router with VLAN grouping capability.
You mention, that the FWA510 has got this.
I downloaded the user's guide from your download site, and in the Feature Differences section (page 17-18), FWA510 does not support VLAN grouping.
Has that been altered after the manual was written?
Best regards,
Claus
This discussion was created from comments split from: Nebula FWA710 vlan missing.
Hi @SomeDane ,
The FWA510 does not support VLAN grouping, as noted in the Feature Differences section. If you need a 5G router with VLAN grouping capabilities, please refer to the Nebula FWA710 User Guide, specifically page 211.
Previously, there was mention that the FWA510 supported VLAN settings on the Cellular WAN, not VLAN grouping feature; however, it is important to clarify that at the time of this writing, VLAN settings on the Cellular WAN is not available on the FWA510 as well.
Zyxel_Judy
Hi @SomeDane ,
Zyxel_Judy
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
