NBG7510 running V1.00 (ABZY.6)C0 not showing all my devices anymore. Why?
tonygibbs16
tonygibbs16 Posts: 979 image  Guru Member
50 Answers 500 Comments Friend Collector Fifth Anniversary
edited April 2024 in Home Router
Hi Zyxel,
My NBG7510 running V1.00(ABZY.6)C0 is not showing all my devices anymore in the WebGUI.
It has been running without a reset for 43 days.
The connectivity picture is only showing 2 hosts connected to the router, which is a reflection of how many NAT sessions the NBG7510 thinks it has, see below.
But I have more than 2 devices working fine on the LAN to the NBG7510.
A reset will probably fix it cosmetically, but does this mask something deeper…
Thoughts?
Kind regards,
Tony
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,403 image  Zyxel Employee
    Hi @tonygibbs16
    Thanks for the feedback.
    Do you mean there are four devices should be shown on the topology before, and indeed the devices show on the topology, however, there is only two devices left on the topology?
    What are the missing devices, are they wireless client or wire clients?
  • tonygibbs16
    edited April 2024
    You're welcome @Zyxel_Jerry . Thanks for your reply.
    Until recently, there were more than 4 devices showing under Traffic Status → NAT and on the topology diagram.
    A mixture of wired and wireless clients were showing.
    Please let me know if you want any logs before I reset the NBG7510.
    Kind regards Tony
  • Zyxel_Jerry
    Hi @tonygibbs16
    Could you send us the configuration file and the login password in private messgae, we would like to check if there is any difference of the configuration.
  • tonygibbs16
    Hi @Zyxel_Jerry
    Thanks for your help. It should be in your Inbox, and a syslog extract.
    Kind regards,
    Tony
