firmware NWA130BE
Hi @GePo ,
As of now, the latest firmware version for the NWA130BE, 675ACIL0C0 is available here for download.
The firmware will be added to the Zyxel Download Library within the next day.
Zyxel_Judy
Hi @GePo ,
Zyxel_Judy
Judy, is it possible to install a "local" file into cloud managed devices? I don´t find a way in GUI (Nebula). Thanks!
Hi @Chris888 ,
The NWA130BE can be updated to the latest firmware via Nebula in the coming days. If you prefer to update immediately, please follow these instructions:
Using ZON:
Using FTP:
Zyxel_Judy
Judy, thanks in advanced! FTP works fine for me!
Still not seeing the firmware for download on Zyxel Download Library.
Try link and update over FTP…very easy…
Hi users,
As of the latest update, to upgrade the firmware of the NWA130BE in standalone mode to version 675ACIL0C0, follow these steps: navigate to Maintenance > File Manager > Firmware Package, click 'Check Now', and then select 'Upgrade'.
Alternatively, you can use the bin file provided and upgrade via ZON or FTP.
The 675ACIL0C0 firmware and release notes for the NWA130BE will be available in the Zyxel Download Library shortly.When managing the NWA130BE via the Nebula cloud, you have the option to upgrade the firmware immediately or schedule it at your convenience. To access this feature, navigate to: Configuration > Firmware Management.
Zyxel_Judy
Download is available now. But why the changelog is empty? Is it a secret or do you have to gues?
Hi @Chris80 ,
It appears you are referring to the "Organization-wide Management > Change Log" section. This feature provides logs for any manual changes made to the configuration settings. For example, if you change the SSID name from "Zyxel_Demo" to "Zyxel_Demo_5GHz" or adjust the radio setting for bandwidth from 80 MHz to 40 MHz, these modifications will be documented here.
Please note that changes made automatically by the access point, such as channel adjustments by DCS, will not be recorded in Change Log section. To view logs for automatic changes, you can navigate to "Monitor > Access Points > Event Log."
Zyxel_Judy
Judy, i‘m talking about the release notes….they are empty.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
