internet lights is green but not working
amir_kenari
hi i have modem del1312-t10b
after config internet lights turn to green and everything look good but when i connect to the modem with laptop or phone say you won't connect to internet i try wifi and cable but nothing work
It looks like this is very old modem, maybe you can try to check the internet status, nat status or factory reset default and config modem again.
tnx but i do everything update firmware and reset factory and config again everything normal but wont connect to the internet
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
