How to set up Android 14 for L2TP via IPSec for ATP100
We use VPN on ATP100 using L2TP (IPSec). Everything still works on Android 12 and older. L2TP (IPSec) is no longer an option on Android 13 and 14. On Android 13 and 14, there is only IKEv2/lPSec MSCHAPv2, IKEv2/lPSec PSK and IKEv2/lPSec RSA.
Which option for Android 13/14 should we select from the image?
    PeterUK Posts: 4,444 image  Guru Member
    You might have to setup without the use of quick start
    setup a Phase 1 Settings in VPN gateway with the following
    show advanced settings
    IKEv2
    Domain Name / Ipv4 0.0.0.0
    set Pre-Shared Key
    Phase 1 settings
    AES128 SHA256
    key group DH14 (one some phones needs to be set higher)
    Phase 2 Setting VPN connection
    Remote Access (Server Role)
    select VPN gateway you made
    Local policy 0.0.0.0
    Configuration Payload setup IP range for VPN
    Phase 2 Setting
    AES128 SHA256
    PFS DH2
    set zone for the VPN
  • Zyxel_Emily
    Hi @JanBab,
    Select "IKEv2 IPSec Client" and follow the guide in this FAQ to install StrongSwan on Andorid.
  • JanBab
    JanBab Posts: 4
    When I start the setup wizard for "Remote Access VPN Setup - IKEv2" via Quick Setup, the message appears: "The Rule has been modified before. Do you want to change the VPN rule?
    Click Yes to change VPN rule through Wizard.
    Click No to exit the Remote Access VPN setup."
    Will the rule also change for "L2TP over IPSec Client"?
  • DialectFalun79177
    DialectFalun79177 Posts: 3 image  Freshman Member
    Is this possible to do With the ZyXEL NSG50 (only Nebula konfig)
    The customer have a new Android 14 with removed L2TP settings
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,665 image  Zyxel Employee
    Hi @DialectFalun79177,
    Since NSG also provides the IPSec VPN function, you can use the StrongSwan App to connect.
    Zyxel Melen
