Multy M1 - Satelits how far from Main Router? How many dBm works fine?
webber1984
webber1984 Posts: 7 image  Freshman Member
edited May 2024 in Multy WiFi System
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @webber1984
    Various environmental factors, such as obstacles, interference from other devices, or signal absorption due to surrounding materials, can impact signal coverage and performance differently.
    In such situations, the effects will vary depending on the type and severity of the environmental influence.
    You can install a satellite and gradually move the devices closer or farther away to find the optimal signal position. Typically, the devices will display dBm for reference to gauge the distance between them.
    However, it's essential to assess the placement based on the current network environment.
