M1 Multy - Problem found, 5G wifi is not working so thats why no mesh. Question, how to solve it?
Why is the 5G network not working??? Channel auto or fix?
Hi @webber1984
To clarify the issue, please respond to the following requests and send us feedback via the Multy App when the issue occurs:
1.How do you connect your Multy device in your environment?
2.How do you determine that the 5G Wi-Fi is not working?
3.When the issue occurs, can other wireless clients detect the 5G Wi-Fi?
You can provide this information when sending us feedback from the Multy App.0 -
Hi, Q1: simple connected with cable to main router (service provider).
Q2: I can connect to the 5G network but any speedtest tools saying no internet, no speed, ping is very high if is there any response
Q3: yes, you can detect, can connect, but there is no internet. And even if a satelite is connecting to this router, the satelit will not work because there is no internet on satelit too.
I restarted this main router xxx times but nothing changed
Hi @webber1984
I have a private message you, please check the message box.0
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
