How to install NWA1123-AC PRO as repeater
Hi @GiuseppeR ,
You're correct. Smart Mesh will adapt to your requirements. Please refer to the following article for step-by-step instructions on how to configure it:
Zyxel_Judy
Hi @GiuseppeR ,
Zyxel_Judy
Hi @Zyxel_Judy
I have different scenarios where the root wifi is made by another vendor, like standard Internet Service Provider.
Can I use the "Smart Mesh" function on Zyxel products also in this case or I have to have at least one Zyxel AP linked with LAN cable as root AP?
Hi @GiuseppeR ,
The Smart Mesh is compatible exclusively with Zyxel access points. Therefore, for your setup, you must connect at least one Zyxel AP via a LAN cable to serve as the root access point.
Zyxel_Judy
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
