Want to disable WPS but button is greyed out
erothe
in Home Router
Hi
I want to hide my SSID, but when I try to do this, I have a message "Hide SSID does not support WPS 2.0. You should disable WPS in WPS page."
But when I go the WPS pane, the WPS button greyed out, what can I do ?
Thank you for your suggestions !
model: AX7501-B0
firmware:v5.17(ABWW.5)C0
Hi
Does anyone know an alternative forum where I could post this question ?
Hello @erothe
Welcome to the forum.
Looking at the user guide available at it says the below:
Are you using more than 1 SSID?
If so, then the above might explain why the WPS button is greyed out.
Kind regards,
Tony
- 217 Nebula Ideas
- 580 USG FLEX H Series
- 297 Service & License
- 475 News and Release
