VMG3925-B10C firmware
Where can I find firmware for VMG3925-B10C?
(Nothing comes up in the search here:
and the answer here is bizarrely useless: https://mysupport.zyxel.com/hc/en-us/articles/360007823860--FAQ-Where-can-I-download-firmware-from
The ftp://ftp.zyxel.com just brings a blank page
I also can’t find the firmware for the VMG3925-B10C
Yes i think they reorganized the site and moved everything to drop box and this special version is not listed anymore.
But the firmware Version 5.13(AAVF.18)C0 is for all device versions :
VMG3926-B10A/VMG3925-B10B/
VMG3925-B10C1 -
Are OK that’s brilliant so 5.13(AAVF.18)C0 this works for all is that correct, thank you for the information, really good of you.
Where can i download 5.13(AAVF.18)C0 many thanks
Just tried FTP
Hello @PeteTech
The file that is listed under VM3925-B10 at https://support.zyxel.eu/hc/en-us/articles/4403361365778-Zyxel-CPE-Devices-Firmware-Advanced-Downloads-Firmwares-and-other-resources as 5.13(AAVF.18)C0 works on 3 models including on VMG3925-B10C according to the release note PDF that is in the ZIP file (see screenshot extract below.)
I hope that this is helpful.
Kind regards,
Tony
Brilliant many thanks my ad blocker stop me downloading the file so i disable d it and have the file now
I believe that this https://support.zyxel.eu/hc/en-us/ is probably a malicious site containing firmware with trojans.
-1
- 441 Beta Program
- 293 Service & License
