Problem with iPhone on Nebula wifi
sfesti
sfesti Posts: 3
image  Freshman Member
Dear Zyxel, I have a problem with a structure of this type:
Nebula cc, nsg50, n.2 a.point nwa1123acv3 n.1 a.point nwa1123acv2 in Italy.
I have had two clients from the USA. with o.s. Apple iOS and I were unable to connect
to wifi with dhcp. I checked later that they took the IP address
as 169.254.165.68 instead of 192.168.10.xx.
Normally with Android I have no problems but with iOS Apple sometimes I can't get them
to navigate. Do you have any suggestions?
Thanks in advance.
Stephen
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,782
    image  Zyxel Employee
    edited May 2024 Answer ✓
    Hi @sfesti ,
    To address the issue of iOS devices not obtaining the relevant IP address when connecting to your Nebula WiFi network, please follow the provided troubleshooting steps:
    • Reset network settings on client: Remove (forget or delete) the SSID profile from the client's Wi-Fi list. Then, attempt to reconnect to the network.
    • DHCP issues: As you mentioned the iOS devices are getting a 169.254.x.x IP address - APIPA, this indicates a failure to obtain an IP address from the DHCP server. Please ensure your DHCP server is functioning correctly and has available IP addresses in the pool.
    • DNS Issues: Verify that the DNS servers assigned by DHCP are accessible and functioning correctly. You can try setting a public DNS server like 8.8.8.8 on one of the affected iOS devices to see if it resolves the issue.
    • iOS version: Upgrade the iOS to the latest version
    You can also utilize the WiFi Aid feature to help identify the issue with the iOS client:
    Resolve WiFi Connection Problems with Nebula's WiFi Aid Feature — Zyxel Community
    If the issue persists, we kindly ask you to enable Zyxel support access and provide the following details so we can assist you further:
    • The name of the Nebula organization and site
    • The MAC address of the affected iOS device and the time it connected to the SSID
    Zyxel_Judy
  • sfesti
    sfesti Posts: 3
    Hi Judy, thanks for the reply. I'll try and I'll tell you. Thanks again. @sfesti
  • Zyxel_Judy
    Hi @sfesti ,
    Zyxel_Judy
  • sfesti
    sfesti Posts: 3
Nebula Tips & Tricks
