How to reflash the last firmware when the previous failed
I would like to know if it's possible to reflash the last firmware when the NAS542 is unreachable.
It is possible that the last flash was completed incorrectly although I am used to doing this.
Thank in advance for your help
Kind regards
  • mich0111
    mich0111 Posts: 3
    edited May 2024 Answer ✓
    I have done a rescuedisk.
    I have used the NAS540 rescuedisk with the firmware of the NAS542.
    It works perfectly.
    My NAS is reachable again.
    Thanks for your help.
  • Mijzelf
    Mijzelf Posts: 3,050 image  Guru Member
    Depends. When the kernel still boots (which doesn't necessarily gives a reachable NAS) you can use a RescueStick. I don't have one for the 542, but the stick for the 540 should also work, when you exchange the .bin file by one from a 542, and put it's md5 sum in the appropriate file.
    But if the kernel still boots, a factory reset might also do the trick. Push the reset button, and keep it pushed until the box has beeped three times. (+/- 20 seconds). If it beeps, the kernel is active.
    When the kernel doesn't boot, it becomes more complicated. You'll need serial access to revive the box.
  • mich0111
    mich0111 Posts: 3
    Thanks a lot.
    If I do this or if I do a factory reset, will I lose all my data?
  • Mijzelf
    Neither will destroy your data. A factory reset deletes the configuration, which means you'll have to reapply users and shares. (The directories are still there, but you'll have to 'promote' them to share).
    A rescue stick only flashes firmware, and leaves everything else as-is.
  • mich0111
    mich0111 Posts: 3
    It works perfectly.
