Did anyone find the ZON utility to be not responding sometimes?
hello,
I installed the ZON software on a new laptop, but it seems to be not sending some configs to the switch everytime, I restart the program and sometimes the config is done but sometimes do not.
for instance I tried lighting locator led, sometimes it works sometimes it doesn't.
is anyone know how to fix this? It did not happen on my other pc.
Hi @ocean77
I assume your OS is Win 10, am I right?
If yes, we have found that Win10pcap will cause some issues working with ZON.
Therefore, the feature of lighting locator led is unable to work.
We have a workaround:
1. Remove win10pcap
2. Install npcap
3. While installing, select "Install Npcap in Winpcap API-compatible Mode" as shown below
Please follow the steps and try again to check the issue still exist or not
Best regards,
Derrick
thank you @Zyxel_Derrick
yes my environment is windows10 , after installing npcap it works smoothly now.
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
