Looking for CLI Manual for NAS542
Calpeman
Calpeman Posts: 4 image  Freshman Member
Hello All,
I'm trying to find the CLI Manual for NAS542 but my Google search doesn't come back with any good result.
Any idea where can I download it from?
Thank you in advance!
  • Calpeman
    Thank you so much! Very useful! Have a great evening!
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    It doesn't exist. The CLI is a Linux CLI, which is far to extensive to catch in a manual. The 542 runs busybox. You can find a list of commands here, but not all commands are implemented. Further there are other binaries added. In many cases you can find their usage on google. And there are also undocumented commands, which are ZyXEL specific. In many cases they start with zy.
    An (incomplete) list of commands can be obtained with:
    ls /bin/
    ls /sbin/
    ls /usr/bin/
    ls /usr/sbin/
  • Calpeman
  • marioos
    marioos Posts: 1
    @pixel speedrun,
    Check the User Manual: The full user manual for the NAS542 might have a section on CLI commands. Try searching the user manual you found for "CLI" or "command line" [user manual ZyXEL NAS542].
    ZyXEL Community: The ZyXEL community forums might have information on using the NAS542 CLI. Search for threads mentioning "NAS542" and "CLI" or similar keywords. You might find users sharing their experience or knowledge about the CLI [ZyXEL NAS 326 CLI manual].
    Generic Linux Commands: Since the NAS542 likely runs on a Linux kernel, many generic Linux commands might work. You can find resources online for common Linux commands to get you started.
