USG60W "wlan_module dead"
- USG60W(4.32) and two NWA5121-NI
- USG40W (4.32) and no managed AP
Hi @Maveloth,
We fix some wireless issues in the latest firmware and I will send you the firmware via private message.
Please upgrade to the firmware and check if the issue is resolved.
If the issue still exists after firmware upgrade, collect the diagnostic file and send the file to us for analysis.
5
Hi @Maveloth,
5 -
Hi Emily,Thank you. I'll upgrade my USG60W as soon as possible. And if I can also one or two other USG to test the firmware.I'll let you know if the problem is solved.0
Hi @Zyxel_EmilyI had updated my USG60W and this is my feedback after 11 days with the new firmware.I've got this message in the log file:
AP Disconnect. MAC:aa:bb:cc:dd:ee:ff,Name:Local-AP,Reason:Idle in RUN State,Model:USG60W
This event is triggered when one or more clients are connected to the internal AP, at first the clients are correctly connected and can access the network devices and internet, then after this message the internal AP is initialized and the clients lost connection.Thanks in advanceMaveloth
Hi @Maveloth,
A new firmware with the fix of the AP Disconnect issue is sent to you via the private message.
Please check your inbox and follow the instructions to upgrade USG60W to this firmware.
Hi @Zyxel_EmilyI had a feedback from the latest firmware ( 4.33(AAKZ.0) ). I did updated my USG60W and now the local AP disconnection reappear, with this error from the log:
<div>2019-02-03 13:23:33 127.0.0.1:58817 alert capwap AP Disconnect. MAC:aa:bb:cc:dd:ee:ff,Name:Local-AP,Reason:Idle in RUN State,Model:USG60W<br></div>
Since I was on V4.32(AAKZ.0)ITS-WK48-2018-11-28-181101110 I didn't had any problem.Thanks in advance.Maveloth
@Nigelo
Sorry but the releasing date is postponed to tomorrow (March. 6th ) due to technical reason.
Charlie0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
