[NEBULA] Can I establish 2 or more simultaneous connection over IPSEC/L2TP ?
In my understanding is yes, you should be able to login VPN with multiple account.
Did you see anything related to VPN in the event logs?0 -
@Lukasz
I notice you also report it on eITS, have reply back please feel free to follow up on ticket.
Thanks~
For everyone who might have the issue when connect L2TP tunnel, you can check.
1. VPN log category, find the negotiation flow stop from which step.
2. If NSG located behind the NAT server then make sure the port forwarding is correct on UDP 4500 and 500
3. Check the L2TP setting such as "L2TP pool" (have enough IP for all clients) or pre-share key via Gateway>L2TP over IPSec client.0
- 588 USG FLEX H Series
- 476 News and Release
