How to turn the 6 GHz radio off on the NWA130BE AP (controlled by Nebula)
Arctic_Hare
Arctic_Hare Posts: 1 image  Freshman Member
edited May 2024 in Nebula
How can I turn the 6 GHz radio OFF on NWA130BE (controlled by Nebula)?
Note: I am not asking how to exclude the 6 GHz band from a specific SSID. I want to turn the 6 GHz radio OFF completely so that the AP is not active on the 6 GHz band until such time that I have WiFi 7 clients.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    edited May 2024
    Hi @Arctic_Hare,
    Normally, we recommend excluding the 6 GHz band from SSIDs for this purpose.
    However, you mentioned you want to disable 6 GHz completely. But Nebula does not have a button to disable 6 GHz radio currently. Therefore, you may ssh to your AP and reference the commands below to configure:
    Router# configure terminal
    Router(config)# wlan slot3
    Router(config-wlan-slot)# no activate
    Router(config-wlan-slot)# exit
    Router(config)#
    In addition, the 6 GHz radio will be enabled after configuring your AP on Nebula or rebooting it.
    Zyxel Melen
Nebula Tips & Tricks
