SSL Certificate download has failed myzyxel-dot-com
Just for information – It works again.
Thanks to the one who did it!0
According to VPN100: Repetitively error: myZyXEL.com Certificate download geometry dash lite has failed, there was a similar issue reported, and it was fixed on the update server.
Make sure your device is running the latest firmware version. If not, consider updating it to see if the issue persists.0 -
Thank you @brendaclawson
I also read that post. But my Zywall 1100 seems to run the latest firmware version.
When I check old e-mails, it seems that this problem happend more than one time before but stopped after a while. I do not know how or why. Maybe someone from @zyxel can help here?0 -
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 497 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
