SSL Certificate download has failed myzyxel-dot-com
Just for information – It works again.
Thanks to the one who did it!0
According to VPN100: Repetitively error: myZyXEL.com Certificate download geometry dash lite has failed, there was a similar issue reported, and it was fixed on the update server.
Make sure your device is running the latest firmware version. If not, consider updating it to see if the issue persists.0 -
Thank you @brendaclawson
I also read that post. But my Zywall 1100 seems to run the latest firmware version.
When I check old e-mails, it seems that this problem happend more than one time before but stopped after a while. I do not know how or why. Maybe someone from @zyxel can help here?0 -
- 441 Beta Program
- 209 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
