VMG devices bridge mode not accessible via it's management IP
k1s
k1s Posts: 73
image  Ally Member
edited February 2024 in Home Router
In this support article:
https://support.zyxel.eu/hc/en-us/articles/360001482220-Setting-the-VMG-as-Modem-Bridge-Mode
...it says after setting the VMG as Modem Bridge Mode…
"The VMG can still be accessed via it's management IP."
But it doesn't seem to work.
For example, if I want to use it VMG3925-B10 in Bridge Mode, and the primary router already has 192.168.1.1 as it's IP address, then Ineed to change the default IP address for VMG3925-B10 from 192.168.1.1 to something else.
I changed mine to 192.168.1.253, turned off DHCP, and firewall, turned on bridge mode, and connected from LAN1 to the WAN port on my primary router.
Now I cannot reach it's configuration management / GUI pages from any device on the primary LAN.
Pinging 192.168.1.253 results in "Destination host unreachable".
The only way I can get to it is connecting directly via it's Wifi (which I want to turn off, so it doesn't interfere with the main WiFi APs in the network).
What settings in the VMG3925-B10 do I need to configure to be able to be able to reach it through the primary LAN router?
  • k1s
    k1s Posts: 73
    image  Ally Member
    edited November 2024 Answer ✓
    I was finally able to resolve it with the help of Synology support who suggested adding a policy route.
    In case anybody finds this post with a similar issue, the set-up is as follows:
    Primary router is Synology RT6600ax, with default IP address 192.168.1.1
    VMG3925-B10C set with an IP address for the configuration pages outside the subnet of the primary router, in my case IP 192.168.5.1 (set under Networking > Home Networking > LAN IP Setup)
    VMG3925-B10C set to bridge mode, set under Networking > Broardband > VDSL > Modify (pencil icon) > Mode "Bridge". My ISP (Onestream) also requires VLAN set to 0 and 101.
    In the Synology router I had to add a manual entry under the internet connection
    …then switch back to PPPoE (where the broadband account username and password details are included).
    Finally, I had to add a policy route like this:
    Network Center > Internet > Smart WAN > Policy Route
    Source IP 192.168.1.0/24
    Destination IP 192.168.5.0/24
    Interface: PPPoE-WAN
    Now I can access the VMG3925-B10C configuration pages at 192.168.5.1 from any PC / device on the primary LAN 192.168.1.x
«134
  • k1s
    k1s Posts: 73
    image  Ally Member
    @Serhii Boiarynov, you are apparently the author of the article, can you please help
  • k1s
    k1s Posts: 73
    image  Ally Member
    Can anybody confirm they can reach their device on the management IP through another router?
  • tonygibbs16
    tonygibbs16 Posts: 979
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    image  Guru Member
    Hello @k1s
    If you connect a standalone computer to LAN1 with a crossover cable and give the computer the IP address of 192.168.1.1 and subnet mask of 255.255.255.0 can you then ping 192.168.1.253 ?
    Kind regards,
    Tony
  • k1s
    k1s Posts: 73
    image  Ally Member
    Yes. the VMG3925-B10 can be pinged with a regular ethernet cable (I don't have a cross over), from any of the VMG3925-B10 LAN ports if the Pc connected directly to it has an IP address in the same range 192.168.1.x.
    But when the VMG3925-B10 is connected from any of its LAN ports to the primary router, then no, it can't be pinged from across the LAN
  • tonygibbs16
    image  Guru Member
    Thanks for your reply @k1s .
    This suggests that it is a routing issue.
    If you do a tracert command then seeing where it stops might help you know where to fix the routing issue?
    - It might be that the primary router needs a static route adding to it, so that it can find the VMG3925-B10 via a specific Ethernet port on the primary router.
    - The primary router might not be able to find it otherwise.
    Kind regards,
    Tony
    PS: If you want to say what make and model the primary router is, then I might be able to find you the command syntax for adding a static route.
  • k1s
    k1s Posts: 73
    image  Ally Member
    Thanks for the reply Tony.
    The primary router is. Synology Rt6600ax
  • Peter2
    Peter2 Posts: 181
    image  Master Member
    You can create a new interface group with an other Lan port and create a new home net with another ip adress . Then you can reach it with an external device on this newly defined Lan Port . When you install a second Lan cable to your Router you access it permanently .
    -I dont know why you dont readressed your Router to 192.168.1.2 and let the modem default adress .
  • k1s
    k1s Posts: 73
    image  Ally Member
    Thanks for your reply Peter. I have 60+devices connecting to the router, so makes more sense to leave that default and change the modem.
    I don't follow the 'create a new home net ' suggestion. Is there a tutorial somewhere or would you mind describing the steps?
  • tonygibbs16
    image  Guru Member
    edited May 2024
    You are welcome @k1s
    https://kb.synology.com/en-uk/SRM/help/SRM/NetworkCenter/lan_static_route?version=1_3 explains how to add a static route.
    I think that you will need to enter which interface the VMG3925-B10 is connected to.
    Hopefully it helps. Please let me know what you think.
    Kind regards Tony
  • Peter2
    Peter2 Posts: 181
    image  Master Member
    edited May 2024
    You could start with making a new interface group if this function is available on the device . Interface group modem including only Lan1 and the WAN . Then define the adress in the section home net .
    Here is an example :
