nsa310 and nsa235-V2 admin doesn't have write access to admin share folders
i didn't edit any file, i got it working by completely reinstalling the whole package but the utf8 error doesn't matter, the "Can't open sessionid.tdb" is probably big thing
Strange. The package contains only two files: /opt/etc/init.d/S09ZyXELSambaReplacement and /opt/etc/samba/ZyXELSambaReplacement.conf. That's it. Don't see what it matters to reinstall these. There is no init script which sets things up. The only 'nasty' thing is in /opt/etc/init.d/S09ZyXELSambaReplacement, on start it executes
# Move /opt/var/lock to ramdrive, else the maintenance of browse.dat will keep the disk awake if [ ! -h /opt/var/lock ] then mv /opt/var/lock/* /var/lock/ rmdir /opt/var/lock && ln -s /var/lock /opt/var/lockfi
but that is executed on each start. (And is the reason the script is S09, to start it early, an nothing is using /opt/var/lock yet). This scriptlet only fires once. When the symlink is created, it stays.
I can imagine that sessionid.tdb is put there. Have you found where it's stored?
i haven't found it but it seems like the samba replacement stops working after a while.
after a few days it goes to "can't open sessionid.tdb" againno idea what could this even mean, the sessionid.tdb, but i cannot use the nas anymore on windows cuz of this error
could it be related to the drive going to sleep after time of idling?
also i've found the sessionid.tdb file to be located in "/var/locks/"
I think i've found what's causing this error. upon losing power unexpectedly and gaining power again it somehow ruins the samba replacement1 -
How? What is ruined?
when the NSA310S loses unexpectedly power, it somehow invokes that sessionid.tdb error, atleast for me. i haven't managed to find out what else was making this issue
That is more a description of the result of the damage than the damage itself. As far a I know 'cannot open sessionid.tdb' can be a difficult way to say samba isn't running.
- 241 Nebula Ideas
- 6.8K Security
- 761 USG FLEX H Series
- 383 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
