Nebula: Bulk import MAC Address for Cloud Authentication
Hi @hexos,
Please reference this file to import MAC Address for Cloud Authentication. In addition, this file can be used in site-wide > Cloud authentication only. This is because org-wide > Cloud authentication import needs to add the authorized site option.
Also, could you help to enable Zyxel support for me to check what's wrong? Please also share your organization's name with me. You may send me a private message if you don't want to share it publicly.
Zyxel Melen0
Hi @hexos,
Zyxel Melen0 -
Hi Melen,
Thank you for the template it works !
I sent you organization and site names in a private message and ZyXEL support is now enabled
Hi @hexos,
Thanks for the privilege and I'm happy the template works.
I just checked the download link on your site and I'm able to download the template with different PCs and browsers.
Could you help to use a different PC, browser, or InPrivate window to download again? Thanks in advance.
Zyxel Melen0 -
Hi Melen,
I tried with 2 differents PC and differents browser (private mode or not) and never been able to download it. It's strange but not very important since you provided me the template
Thank you for your help !
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 499 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
