NAS542 rsync
I installed rsync on the NAS and transferred successfully files from my PC to the NAS, using the cygwin version of rsync.
In the PC client, only the volumes on the NAS are selectable as destination.
These do not appear in the filebrowser, where you only can see shares.
How can I access my files on the NAS side ?
  • Mijzelf
    Mijzelf Posts: 2,933  Guru Member
    The shares are in the volumes. So what is the problem?
  • howi42
    howi42 Posts: 2
    Thanks, problem is solved.
    I am using DeltaCopy to backup my files.
    DeltaCopy creates, as expected, a folder on the volume, but to see this folder as a share, I had to define it as such manually .
    No real problem, I just had to find out.
