SLA in my license
Our IT Audit would like to know any SLA for our license in the firewall and Access point. So where I can get the information?
We are using some USG FLEX 100, 100W and NWA50AX. Thanks!
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279 image  Guru Member
    Hi @RMC
    We do have the End User License Agreement. Could you please check if this is the document you are looking for?
    If not, could you please specify what kind of information you need from the agreement?
    Kay
Service & License Help Center
