Any firmware updates for Armor G5
Hi @dursun
The Armor G1 device does not support VLAN tagging.
Thanks for your valuable feedback.
We appreciate your suggestion and will consider this feature in future products.0 -
There is a release note for V1.00(ABSK.8)C0 from November (August) 2022 at https://www.zyxel.com/uk/en-gb/support/download?model=armor-g5-nbg7815 , see below.
The installation using the Wizard should check for the latest firmware.
@Zyxel_Jerry Is the bin file available for the latest firmware, so that it can be updated by users?
- the user guide suggests that it should be downloadable from somewhere…
Kind regards,
Tony
Hi @tonygibbs16
Thanks for feedback.When doing installation and run the wizard, the device will check if there is a new firmware available, if there is no internet at the time, the device cannot check it.
It seems that is documentation error, on the Chapter 13.6, the firmware is not able to download on the www.zyxel.com, we will modify the document.1 -
Where can I find the last Firmware (08) for Armor G5? Link from the side "discontinued hardware" is dead :(
Hi @bimbi
The Armor G5 is using a cloud upgrade.
You can go to Overview and click the upgrade button if you are not in the latest version.1
- 217 Nebula Ideas
- 574 USG FLEX H Series
- 297 Service & License
- 473 News and Release
