XGS1930 - Routing trouble
2»
    PeterUK Posts: 4,430 image  Guru Member
    Yes this is why I think L2 switch can't do this I know my L2+ NETGEAR M4100-D12G and L3 Cisco
    SG350-10 can so its down to what switch you need.
    I have a Zyxel L2 GS2210-24 which also can't do this type of routing
  • mauro83
    mauro83 Posts: 7 image  Freshman Member
    edited June 2024
    I think the same ….you think the zyxel XGS2220 can do what i need?
    edited June 2024
    I would hope so but maybe Melen can comment?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,643 image  Zyxel Employee
    Hi @mauro83 & @PeterUK,
    You don't need to set static route rules on the Zyxel switch that supports VLAN routing. Our layer 3 switch, includes XGS1930, will automatically create a routing rule after you configure an IP address to your VLAN.
    You may check the IPv4 routing table. Path is Menu > Management > Routing table > IPv4 Routing table. The below screenshot is my example.
    So, you only need to set the static route on the firewall:
    IP 192.168.33.0/24 gateway 192.168.11.2
    IP 192.168.22.00/24 gateway 192.168.11.2
    Zyxel Melen
