USG Flex Backup WAN Connection - Timer?
Hello @Andye
Please refer to our lab test result:
The ATP100 has two WAN interfaces.
The backup interface is set to WAN2.
We used a PC to get a DHCP IP from the LAN1 interface and ping 8.8.8.8 through the WAN1 interface. When the WAN1 port is manually disconnected, there will be a ping drop, but the ping packets will fail over to the WAN2 interface immediately. Therefore, the failover should be fast.
Hello @Andye
- 441 Beta Program
- 293 Service & License
